Join the Fabric FabCon Global Hackathon—running virtually through Nov 3. Open to all skill levels. $10,000 in prizes! Register now.
zigmondsrh
Power BI Power Pivot Use a different measure for grand total than what was used for the column
I have a column that is showing the average head count required for each of the 48 thirty minute intervals in a 24 hour day.  I need the grand total row to divide the grand total result by 2.  I do not want the column meausre to divide by 2.  I only need the grand total to be divided by 2.  The following is the measure currently in the pivot table.
=SUMX(SUMMARIZE(subquery_Forecast_Accuracy_INT,[INTRVL]),CALCULATE([PWBI.REQHOURS_AVG_ACTUAL]))
"subquery_Forecast_Accuracy_INT" is the name of the table.
"[INTRVL]" is the summarize level or Group By statement.
"[PWBI.REQHOURS_AVG_ACTUAL]" is simply taking the column with the required hours data and dividing that by a distinct count of all the records with actual data.
Since there are two intervals in an hour, I have to divide the grand total by 2 to get the total hours required for the day.  How can I get the grand total to divide by 2 without applying the divide by 2 to the individual interval data?
Hi @zigmondsrh
Maybe you can try to use the HASONEVALUE() function.
HASONEVALUE function (DAX) - DAX | Microsoft Learn
For example, I create a set of sample:
Then the HASONEVALUE() can return the True or False in different level of the matrix:
Measure =
HASONEVALUE('Table'[Value])
So you can use IF() function to get the right target like this:
MEASURE =
VAR _A =
    SUMX (
        SUMMARIZE ( subquery_Forecast_Accuracy_INT, [INTRVL] ),
        CALCULATE ( [PWBI.REQHOURS_AVG_ACTUAL] )
    IF ( HASONEVALUE ( YourValue ), _A, _A / 2 )
Zhengdong Xu
lbendlin
Please provide sample data that covers your issue or question completely, in a usable format (not as a screenshot).
Do not include sensitive information or anything not related to the issue or question.
If you are unsure how to upload data please refer to https://community.fabric.microsoft.com/t5/Community-Blog/How-to-provide-sample-data-in-the-Power-BI-...
Want faster answers? https://community.fabric.microsoft.com/t5/Desktop/How-to-Get-Your-Question-Answered-Quickly/m-p/1447...
