MacJasem
Helper III
Helper III
Need help with a DAX measure issue, that doesn't filter correctly.
hi Guys/Girls
I've got a measure [FilteredTotal] & [Total], and i'd like to create a measure that returns the value from [Total] when the filter is active on the page, or else if filte is not active return the value for [FilteredTotal].
ConditionalTotal =
IF (
    ISFILTERED(ChartOfAccounts[Name]),
    [Total],
    [FilteredTotal]
but this doesn't really work, because the value for [Total] still shows when no filter is chosen.
what might be the problem? please ask if you need more info to answer/help
Hi @MacJasem,
Can you please share a pbix or some dummy data that keep the raw data structure with expected results? It should help us clarify your scenario and test to coding formula.
Xiaoxin Sheng
some_bih
Hi @MacJasem you put filter on account Finance[Account_No] > 1000, this cause this unexpected calculation. Is this what you want?
On visual you can exclude subtotal for rows / columns.
yes this is intended because this is the only difference between Total and FilteredTotal measures, so i want to switch between those two measures depending on the filter choice
some_bih
Hi @MacJasem it must be something about one of your measure definition.
I guess you want to controll some subtotal/total in table /matrix. If yes, when you need to workout your measure. Hope this help kudos appreciated.
Thanks @some_bih for the feedback
the two measures that i want to switch between are:
Total =  SUM ( Finance[Sum_Amount] )
and
FilteredTotal = SUMX(FILTER(Finance, Finance[Account_No] > 1000), Finance[Sum_Amount])
I really can't seem to figure out what the issue is.
I have a clustered column chart as the visual where i'd want the measure to switch between the result of the above two measures.
