Hi @MacJasem,
Can you please share a pbix or some dummy data that keep the raw data structure with expected results? It should help us clarify your scenario and test to coding formula.
Xiaoxin Sheng
Hi @MacJasem you put filter on account Finance[Account_No] > 1000, this cause this unexpected calculation. Is this what you want?
On visual you can exclude subtotal for rows / columns.
yes this is intended because this is the only difference between Total and FilteredTotal measures, so i want to switch between those two measures depending on the filter choice
Hi @MacJasem it must be something about one of your measure definition.
I guess you want to controll some subtotal/total in table /matrix. If yes, when you need to workout your measure. Hope this help kudos appreciated.
Thanks @some_bih for the feedback
the two measures that i want to switch between are:
25 | |
12 | |
8 | |
6 | |
6 |
26 | |
12 | |
11 | |
9 | |
6 |
