Get registeredGet Fabric Certified for FREE during Fabric Data Days. Don't miss your chance! Learn more
I have an input method format as shown below in the image(which is obtained through powerapps)
Where the input date has a 'one to one' relationship with the dim date table
Illustration Purpose: This is how values are stored in the dashboard
Dim input table
DAX Formula
By using the above formulation I want to achieve the following output:
But I get this as my output
Am I missing out something in the formulation?
this code might work
Output=VAR vCurrentDate=max(dimDateTable[Date]) RETURN CALCULATE(SUM(Input[Value]),Input[Date]<=VCurrentDate)
Hi @AntrikshSharma ,
Thanks for the reply
But my values dont get stored as different columns but as a single view for each input case
For example: For input- Input value- 300 @ input date: jun 2021
| jun 2020 | 0 |
| dec 2020 | 0 |
| jun 2021 | 300 |
| dec 2021 | 300 |
| jun 2022 | 300 |
| dec 2022 | 300 |
For input- Input value- 100 @ input date: dec 2021
| jun 2020 | 0 |
| dec 2020 | 0 |
| jun 2021 | 0 |
| dec 2021 | 0 |
| jun 2022 | 100 |
| dec 2022 | 100 |
So each of it is a single view and then finally i want to add them similar to final input above
Thanks mate!
Worked like a charm
@Anonymous Try something like this:
SUMX (
DimInputTable,
DimInputTable[Column 1] + DimInputTable[Column 2] + DimInputTable[Column 3]
| 9 | |
| 5 | |
| 3 | |
| 3 |
| 23 | |
| 12 | |
| 11 | |
| 9 | |
| 8 |
