Anonymous's avatar
6 years ago
Need help with DAX Formulation for sum using equality operator Date columns
I have an input method format as shown below in the image(which is obtained through powerapps)
Where the input date has a 'one to one' relationship with the dim date table
Illustration Purpose: This is how values are stored in the dashboard
     Dim input table
DAX Formula
By using the above formulation I want to achieve the following output:
But I get this as my output
Am I missing out something in the formulation?
  • this code might work
    Output=VAR vCurrentDate=max(dimDateTable[Date]) RETURN CALCULATE(SUM(Input[Value]),Input[Date]<=VCurrentDate)
  • AntrikshSharma's avatar
    AntrikshSharma
    Anonymous  Try something like this:
    SUMX (
        DimInputTable,
        DimInputTable[Column 1] + DimInputTable[Column 2] + DimInputTable[Column 3]
    Hi AntrikshSharma ,
    Thanks for the reply
    But my values dont get stored as different columns but as a single view for each input case
    For example: For input- Input value- 300 @ input date: jun 2021
    jun 20200
    dec 20200
    jun 2021300
    dec 2021300
    jun 2022300
    dec 2022300
    For input- Input value- 100 @ input date: dec 2021
    jun 20200
    dec 20200
    jun 20210
    dec 20210
    jun 2022100
    dec 2022100
    So each of it is a single view and then finally i want to add them similar to final input above
    • wdx223_Daniel's avatar
      wdx223_Daniel
        Thanks mate!
        Worked like a charm
