marcomartinetti
Insert New column using values from another column - Power BI Desktop
Hi communuty,
I would need a hand to figure out how to create a new column in an existing table by taking data from another table.
I tried to use the formula :
CMP =
var article code = Vendite[K_CodArt]
var data = Vendite[K_DataRegistraz]
var costo = MAXX(FILTER('CMP', art = 'CMP'[Articolo] ), 'CMP'[VALORENETTOSCHEDA] )
return
costo
so it would work, but the problem is that I should be able to filter both the data and the article code.
Can you help me figure out what formula I should use to be able to use both filters??
thank you very much
Marco
Mahesh0016
@marcomartinetti I hope this helps you!Thank You!!
CREATE Column :
CMP = lookup([VALORENETTOSCHEDA],[Articolo],[K_CodArt])
oh wow ok! I had never used this feature.
but this feature is fine even if I have to use a double filter? item code and date? or is it just fine with a filter?
@marcomartinetti Yes , you can use in calculate function then apply filter.
For E.g
CMP = calculate(lookup([VALORENETTOSCHEDA],[Articolo],[K_CodArt]), filter(conditions)).
@marcomartinetti THANK YOU!!
marcomartinetti
thank you @Mahesh0016
So, I would like to link to each marketing move a cost that is present in the second table
table 1                                                   table 2
way to merge these two tables would be by making filter for column K_CodArt and K_DataRegistraz of the first table.
the result that I would like to have would be to bring up the VALORENETTOSCHEDA column of the second tables in the first.  Such as in the image :
Thank you
Marco
Mahesh0016
@marcomartinetti Please Share Expected OutPut in table.
