Daxtothemax's avatar
Daxtothemax
4 years ago
Difference between two values in same column
Looking for a way in Power BI to calculate the difference between values in the same column. Need the day over day change to the remaining duration. I have a formula that works but an issue has come ...
    4 years ago
    Hi Daxtothemax ,
    Please check the formula.
    _flag =
    var a = CALCULATE(SUM(DS[Remaining Duration]),FILTER(DS,DS[date]=EARLIER(DS[date])-1&&DS[Task]=EARLIER(DS[Task])))
    return
    if(a=blank()||a>=DS[Remaining Duration],1,0)
    change =
    var _date = CALCULATE(MAX(DS[date]),FILTER(DS,DS[date]<EARLIER(DS[date])&&DS[Task]=EARLIER(DS[Task])&&DS[_flag]=1))
    var _value = CALCULATE(SUM(DS[Remaining Duration]),FILTER(DS,DS[Task]=EARLIER(DS[Task])&&DS[date]=_date))
    return
    IF(_value <DS[Remaining Duration],0,_value-DS[Remaining Duration])
    Jay
