Daxtothemax
4 years agoDifference between two values in same column
Looking for a way in Power BI to calculate the difference between values in the same column. Need the day over day change to the remaining duration. I have a formula that works but an issue has come up when durations are actually increased. I would prefer to not show negative change and the change be based off the original duration only. Please see existing formula and example data below.
Any help is greatly appreciated!
- Anonymous4 years ago
Hi Daxtothemax ,
Please check the formula.
_flag = var a = CALCULATE(SUM(DS[Remaining Duration]),FILTER(DS,DS[date]=EARLIER(DS[date])-1&&DS[Task]=EARLIER(DS[Task]))) return if(a=blank()||a>=DS[Remaining Duration],1,0) change = var _date = CALCULATE(MAX(DS[date]),FILTER(DS,DS[date]<EARLIER(DS[date])&&DS[Task]=EARLIER(DS[Task])&&DS[_flag]=1)) var _value = CALCULATE(SUM(DS[Remaining Duration]),FILTER(DS,DS[Task]=EARLIER(DS[Task])&&DS[date]=_date)) return IF(_value <DS[Remaining Duration],0,_value-DS[Remaining Duration])Best Regards,
Jay
- tamerj1
Hi Daxtothemax
You may try
Diff = VAR TaskTable = CALCULATETABLE ( DS, ALLEXCEPT ( DS, DS[Task] ) ) VAR FirstDate = MINX ( TaskTable, DS[Date] ) VAR FirstDuration = MAXX ( FILTER ( TaskTable, DS[Date] = FirstDate ), DS[Hrs] ) VAR Result = FirstDuration - DS[Hrs] RETURN IF ( Result < 0, 0, Result ) - AnonymousNot applicable
Hi Daxtothemax ,
Jay
