Please assist with Dax syntax for measure to subtract the Med All value for the max date minus Min date for value in same column. The user will select 2 "As of Dates" for the calculation. Column name is Med All.
16,186 - 16,128 = 58
thanks for your assistance!
@Anonymous , Try measure like
Diff =
var _max = maxx(allselected('As on date'), 'As on date'[Date])
var _min = minx(allselected('As on date'), 'As on date'[Date])
return
calculate(sum(pptcount[med all]) , filter('As on date', 'As on date'[Date] =_max)) -calculate(sum(pptcount[med all]) , filter('As on date', 'As on date'[Date] =_min))
Diff =
return
thank you! That was the syntax I needed.
| 20 | |
| 10 | |
| 9 | |
| 4 |
| 33 | |
| 31 | |
| 19 | |
| 12 | |
| 11 |
