Dax: Calculate difference between 2 values in same column based on date selection
Please assist with Dax syntax for measure to subtract the Med All value for the max date minus Min date for value in same column. The user will select 2 "As of Dates" for the calculation. Column name is Med All.
16,186 - 16,128 = 58
thanks for your assistance!
Anonymous , Try measure like
Diff =
var _max = maxx(allselected('As on date'), 'As on date'[Date])
var _min = minx(allselected('As on date'), 'As on date'[Date])
return
calculate(sum(pptcount[med all]) , filter('As on date', 'As on date'[Date] =_max)) -calculate(sum(pptcount[med all]) , filter('As on date', 'As on date'[Date] =_min))
- amitchandak
Diff =
return
calculate(sum(pptcount[med all]) , filter('As on date', 'As on date'[Date] =_max)) -calculate(sum(pptcount[med all]) , filter('As on date', 'As on date'[Date] =_min))- AnonymousNot applicable
thank you! That was the syntax I needed.
