I have a spreadsheet from a car report that my team fill in monthly on different dates. Their mileage they enter is their odometer reading, so i need to work out the difference between that and their previous reading
The data looks like this:
Start time | Name | Current mileage: |
3/27/20 15:09:35 | Person 1 | 21056 |
3/31/20 11:13:16 | Person 2 | 17513 |
5/5/20 14:49:32 | Person 2 | 17616 |
5/6/20 10:03:44 | Person 3 | 21402 |
5/7/20 10:14:50 | Person 1 | 21648 |
6/1/20 8:54:29 | Person 3 | 21531 |
6/1/20 9:11:23 | Person 1 | 22200 |
6/8/20 10:36:50 | Person 2 | 17760 |
7/1/20 13:37:04 | Person 1 | 22900 |
7/6/20 10:02:11 | Person 2 | 18080 |
7/31/20 10:08:35 | Person 1 | 24043 |
8/3/20 11:52:18 | Person 2 | 18781 |
9/1/20 8:47:56 | Person 3 | 22854 |
9/2/20 15:54:48 | Person 2 | 19440 |
9/3/20 9:29:27 | Person 1 | 26333 |
9/30/20 13:28:51 | Person 3 | 23613 |
10/1/20 10:17:13 | Person 2 | 20848 |
10/2/20 13:48:17 | Person 1 | 27107 |
10/30/20 12:12:39 | Person 1 | 29305 |
11/2/20 10:09:31 | Person 3 | 24688 |
11/3/20 10:52:01 | Person 2 | 22713 |
11/30/20 9:49:12 | Person 1 | 30276 |
12/8/20 12:55:57 | Person 2 | 23777 |
12/28/20 15:18:14 | Person 1 | 30049 |
1/4/21 10:28:35 | Person 2 | 24036 |
1/13/21 12:46:53 | Person 3 | 25269 |
1/29/21 10:06:16 | Person 3 | 25466 |
2/1/21 8:26:55 | Person 1 | 31426 |
2/1/21 16:11:59 | Person 2 | 24194 |
3/1/21 8:56:05 | Person 1 | 320011 |
3/1/21 13:40:59 | Person 2 | 24422 |
3/8/21 8:43:38 | Person 3 | 25936 |
3/31/21 7:46:11 | Person 1 | 33038 |
3/31/21 9:59:18 | Person 3 | 26327 |
I need to be able to work out monthly mileage, based on their monthly mileage readings. Because they all do this on different dates it creates problems using date in the dax
(ie I tried this difference =
) so i wondered if i could just calculate the difference between the most recent and previous reading for each person?
The worksheet formula is powerful enough,
| Thanks to the great efforts by MS engineers to simplify syntax of DAX! Most beginners are SUCCESSFULLY MISLED to think that they could easily master DAX; but it turns out that the intricacy of the most frequently used RANKX() is still way beyond their comprehension! |
DAX is simple, but NOT EASY! |
This was a geat help - but now it has thrown up another issue:
I have a mileage spreadsheet and in it I am using the following measure to work out how much mileage they have done in each month:
Hi @gingerclaire ,
According to your description, your formula is 'Car report data'[Current mileage:]-'Car report data'[Prev Reading], if there is no previous reading, how can it get the negative number, can't reproduce it.
But if that's the case, here's my solution:
Mileage since last month2 =
- IF (
'Car report data'[Prev Reading] <> BLANK (),
0
Community Support Team _ kalyj
Thank you - is that a measure or a calculated column please?
@gingerclaire See my article on Mean Time Between Failure (MTBF) which uses EARLIER: http://community.powerbi.com/t5/Community-Blog/Mean-Time-Between-Failure-MTBF-and-Power-BI/ba-p/3395....
The basic pattern is:
Column =
VAR __Current = [Value]
VAR __PreviousDate = MAXX(FILTER('Table','Table'[Date] < EARLIER('Table'[Date])),[Date])
VAR __Previous = MAXX(FILTER('Table',[Date]=__PreviousDate),[Value])
__Current - __Previous
I must admit I came across it when searching the boards for a solution/inspiration, but as a beginner, I couldn't keep up.
| 20 | |
| 11 | |
| 10 | |
| 4 |
| 34 | |
| 31 | |
| 19 | |
| 12 | |
| 11 |
