Hi experts,
Note: I am looking for what wrong I am doing and bit of explanation or links to the solution so I can learn.
I am not quite sure but my average keep filter and remove filter shows same value.
I have written some measure on the test sample:
1. avgnofilter: I used remove filter on table and columns and tried but this and
avgNoFilters = DIVIDE(Agegroup[FilCount],CALCULATE(Agegroup[TotalCount],REMOVEFILTERS(Agegroup)))2. avgNoAgeGrooupFilter: I wanted a measure for average of selected column
avgNoAgeGroupFilter = DIVIDE(Agegroup[FilCount],CALCULATE(Agegroup[TotalCount],KEEPFILTERS(Agegroup)))
Unfortunately Both results show same answer, I think I am making some mistakes
What I want is Avg of selected column for over all column with no filters
Example:
1. Average of selected column say Age range: 10-20 Y, I am looking for average of this across age groups
2. when I add a country to the filter, when I select say Brazil, i need the average of Brazil, with that age group against over all average NO filters at all.
3. Same as 2 but I need average of selected items average of Brazil for all age groups.
thank you for your help.
Hi @Anonymous ,
Is this what you want?
avgNoFilters 2 = DIVIDE([FilCount],CALCULATE( COUNT(Agegroup[ID]),ALLSELECTED( Agegroup[Age group])))avgNoFilters 3 = DIVIDE([FilCount],CALCULATE( COUNT(Agegroup[ID]),REMOVEFILTERS( Agegroup[Age group])))
Icey
Hi @Anonymous ,
Icey
| 8 | |
| 6 | |
| 3 | |
| 3 | |
| 3 |
| 11 | |
| 9 | |
| 8 | |
| 7 | |
| 6 |
