Anonymous's avatar
6 years ago
PrevRow + index problem
Guys, i'm using dax to get my prev row value based on my index number.
First, let's have a look at my table
Ok, i need to sort first by my ID number to group all values that are the same, then i need to sort by date/time, to get the order of how our process was done.
Then i created my index to get my prev value using a var.
The problem is, when my BI are updated, a new item enter as my last index and doesnt group with the other id numbers.
And this new item will not be counted in my process because it dont fill the requirementes of my if.
This is how i got my prev row "
Acionamento =
var idx = [Index]
var id_num = [ID Number]
return
CALCULATE(MAX([Changed On Timestamp]),FILTER(table, 'table'[Index] = idx-1 )))"
So, i have no idea how to fix it.
  • Hello @Vieiraguilherme ,
    You can create this computed column instead of the index column:
    Sort =
    VAR _rank =
        RANKX (
            FILTER ( ALL ( 'Table' ), 'Table'[ID Number] = EARLIER ( 'Table'[ID Number] ) ),
            'Table'[Changed On Timestamp],
            ASC,
            DENSE
    VAR _sort =
        IF (
            [ID Number] = MIN ( 'Table'[ID Number] ),
            _rank,
            _rank
                + CALCULATE (
                    COUNTROWS (
                        FILTER ( ALL ( 'Table' ), 'Table'[ID Number] < MAX ( 'Table'[ID Number] ) )
        _sort
    Next, create a measure to get the previous row:
    _prerow =
        MAX ( 'Table'[Changed On Timestamp] ),
        FILTER (
            ALL ( 'Table' ),
            'Table'[Sort]
                = CALCULATE (
                    MAX ( 'Table'[Sort] ),
                    FILTER ( ALL ( 'Table' ), 'Table'[Sort] < MAX ( 'Table'[Sort] ) )
    Current Result:
    When you add a new row to the table, the value of the previous row is still received successfully:
    Attached a sample file in the next one, hopes to help you.
    Best Looks,
    Yingjie Li
    If this post helps, please consider Accepting it as the solution to help the other members find it more quickly.
  • Anonymous , Try like
    new measure
    Acionamento =
    CALCULATE(MAX([Changed On Timestamp]),FILTER(table, 'table'[Index] = max( 'table'[Index] )-1))
    new column
    Acionamento =
    CALCULATE(MAX([Changed On Timestamp]),FILTER(table, 'table'[Index] = earlier( 'table'[Index] )-1))
  • v-yingjl's avatar
    v-yingjl
    Sort =
    VAR _rank =
        RANKX (
            ASC,
            DENSE
    VAR _sort =
        IF (
            _rank,
            _rank
                + CALCULATE (
                    COUNTROWS (
        _sort
    _prerow =
        FILTER (
            ALL ( 'Table' ),
            'Table'[Sort]
                = CALCULATE (
    Current Result:
    Best Looks,
    Yingjie Li
      Hi, do you thing this collumn/measure will work with a BI that have 250.000 rows?
      • v-yingjl's avatar
        v-yingjl
        Hi Anonymous ,
        The calculated column and measure both should work.
