Plotting data with meter coordinates system in power BI
Hi there,
I have x and y coordinates (their unit is in 'meters') and sample data is as follow:
| Point_x | Point_y | |
| 1393427.246 | 4916767.201 | |
| 1404938.962 | 4914923.079 | |
| 1408257.588 | 4919262.785 | |
| 1408578.911 | 4919268.221 | |
| 1393367.994 | 4916913.063 | |
| 1405745.535 | 4918565.383 | |
| 1404544.502 | 4915702.339 | |
| 1415210.388 | 4923001.518 | |
| 1408309.682 | 4919617.785 | |
| 1413830.141 | 4923060.024 | |
| 1403506.74 | 4919101.903 | |
| 1403898.004 | 4918221.265 | |
| 1407236.984 | 4920485.674 | |
| 1404360.046 | 4917812.396 | |
| 1403262.267 | 4918450.047 | |
| 1413788.987 | 4923072.168 | |
| 1415105.556 | 4922993.073 | |
| 1404331.45 | 4915868.449 | |
| 1405317.606 | 4914014.232 | |
| 1408775.876 | 4919359.098 | |
| 1407116.939 | 4920413.94 |
The data type of both columns are as shown in the figure:
However, when I tired to plot the data into map, it does not show any points on the map as shown in the figure:
I am not sure why its not plotting. Not sure whether power BI supports the 'meters' as a coordinate system to plot the data. Typical demical degree used for the plotting,. Could anyone help me in rectifying the issue?
Dunner2020 This coordinate position (in meters) seems US-based "state plane" and it is derived using 3 information Zone, X and Y. Please check this website for more information and conversion: https://www.earthpoint.us/Convert.aspx (check for state plane in details below)
Once you're able to convert from the current metric to Long Lat only then your plotting will be correct.
Amit
- Greg_DecklerCommunity Champion
Dunner2020 You are going to have to convert whatever that is into proper longitude and latitude:
- Dunner2020Post Prodigy
Greg_Deckler , I tried that calculation mentioned in the post. The value produced after the calculation were quite big. So I dont think its right calculation to perform.
- amitjzaveriResolver II
Amit
Please check this as I guess you will have to convert and plot.
Display Points within a Distance Radius on a Power BI Map
https://dataveld.com/2019/03/20/display-points-within-a-distance-radius-on-a-power-bi-map/
Cheers!
