Dunner2020
Post Prodigy
6 years agoPlotting data with meter coordinates system in power BI
Hi there, I have x and y coordinates (their unit is in 'meters') and sample data is as follow: Point_x Point_y 1393427.246 4916767.201 1404938.962 4914923.079 1408257.588...
- 6 years ago
Dunner2020 This coordinate position (in meters) seems US-based "state plane" and it is derived using 3 information Zone, X and Y. Please check this website for more information and conversion: https://www.earthpoint.us/Convert.aspx (check for state plane in details below)
Once you're able to convert from the current metric to Long Lat only then your plotting will be correct.
Amit
amitjzaveri
Resolver II
6 years agoPlease check this as I guess you will have to convert and plot.
Display Points within a Distance Radius on a Power BI Map
https://dataveld.com/2019/03/20/display-points-within-a-distance-radius-on-a-power-bi-map/
Cheers!
