Dunner2020
Post Prodigy
6 years agoPlotting data with meter coordinates system in power BI
Hi there, I have x and y coordinates (their unit is in 'meters') and sample data is as follow: Point_x Point_y 1393427.246 4916767.201 1404938.962 4914923.079 1408257.588...
- 6 years ago
Dunner2020 This coordinate position (in meters) seems US-based "state plane" and it is derived using 3 information Zone, X and Y. Please check this website for more information and conversion: https://www.earthpoint.us/Convert.aspx (check for state plane in details below)
Once you're able to convert from the current metric to Long Lat only then your plotting will be correct.
Amit
Greg_Deckler
6 years agoDunner2020 You are going to have to convert whatever that is into proper longitude and latitude:
Dunner2020
Post Prodigy
6 years agoGreg_Deckler , I tried that calculation mentioned in the post. The value produced after the calculation were quite big. So I dont think its right calculation to perform.
