connect Excel to power Bi - Power Query
Dears,
Greeting
I have a power query in excel with applied steps
Now, I need to connect the same power query from excel to Power BI with taking consider applied steps in excel
What do I want the file to do?
I want when filling data in the data source in the excel file then reflect automatically in power bi
How I do that?
MattAllington
There is no option for live links. If you have a query in Excel, then you need to trigger a refresh in Excel, materialise the table into a sheet and save the file, then refresh PBI. Alternatively you may be able to move the query to PBI and only use Excel for data entry. You will still have to save the file (or course) but you won't have to trigger the query refresh in Excel. In PBI.com you can then refresh on a schedule, or presumably you could use Power Automate to detect the change in the Excel file and trigger a refresh.
* Matt is an 8 times Microsoft MVP (Power BI) and author of the Power BI Book Supercharge Power BI.
I will not give you bad advice, even if you unknowingly ask for it.
Thank you, Mr.Matt
Yeah, of course, IF I want to use excel only data entry and import data in PBI is a method (create new PQ in PBI) but I was already designed in excel power query (big data with modifications) wherefore I need a way to move power query in excel with "modifications" to design a dashboard in PBI .. what I need is when I filing data in excel & click refresh is reflected automatically in PBI dashboard.
Hello @Anonymous
why you don't transfer the power query code from Excel to Power BI and use in case Excel to read the data you entered there? So whenever you go to power BI the data is read from your original data source and from Excel, and thats it? Or I'm missing something?
Kudoes are nice too
Have fun
Jimmy
