Learn moreLevel up your Power BI skills this month - build one visual each week and tell better stories with data! Get started
Hey Everyone,
I have an urgent scenario where I want the following to happen:
a) I authenticate to an API via Power BI and if it returns a success go to step (b)
b) Retrieve data for a unique id from a sql database and display it in a Power BI report
I am thinking I can probably do something like this:
IF (Person has access) then get data
Else Exit and Show a message
End
Is this possible using Power Query? if yes, can someone please give me some code ideas?
Nimish
not yet. ask again in a couple of weeks.
Hi @raduser ,
not quite sure about your requirement, but mayby my latest article gives you some ideas: https://www.thebiccountant.com/2020/09/19/retrieve-header-fields-like-response-status-power-bi-and-p...
| 3 | |
| 2 | |
| 2 | |
| 2 | |
| 2 |
