ssaintlouis
Refresh problem on Power Pivot
Does anybody have a solution for this kind of problem please (power pivot Excel 2019) ? Ihave been at this for a long time. Thx in advance....
v-jingzhang
Hi @ssaintlouis
According to the error message, the connection may be broken. You can go to Data > Existing Connections to verify the connections in the current workbook. If a connection is not configured correctly, you can right click on the connection and click "Edit Connection Properties..." to configure it.
Community Support Team _ Jing
v-jingzhang
Hi @ssaintlouis
Thx man, it solved my problem
60 days of Data Days Carousel
Data Days 2026
