Betty888
Helper II
Helper II
R in Power suery : How to extend my code that works by group to all data
Dear all,
I'm trying to analyse the effect of "Factor1" and "Factor2" on the response variable "perf" by "location", and obtaining at the end my original dataset associated to the lsmeans and tukey groups letters. Here below the code I'm using that gives me exactly what I need but only by location, my need is : how can I extend it in a way my output combines results of all locations, i.e, output of lsmeans and CLD by location :
library(multcomp)
library(lsmeans)
library(dplyr)
library(broom)
output <- as.data.frame(dataset)
output$perf <- as.numeric(output$perf)
output$factor1 <- as.factor(output$factor1)
output$factor2 <- as.factor(output$factor2)
output <- output %>%
           group_by(location) %>%
           mutate(row=row_number())
model <- lm(perf ~ factor1 + factor2, data = output)
lsmeans <- lsmeans(model, ~ factor1)
CLD = cld(lsmeans,
            alpha   = 0.05,
            Letters = letters,
            adjust  = "tukey")
output <- left_join(output, CLD, by = "factor1")
Thank you in advance for your help !
Hi @Betty888
You can consider to create a new column instead of group_by, you can refer to the following link, it may help you.
Concatenating strings with multiple separators using paste() in R - Stack Overflow
Best Regards!
Yolo Zhu
Hi @Betty888
Best Regards!
Yolo Zhu
Many thanks !
