DM0010
Problem with tables in Power Query Editor due to ODBC
Hi all!
I have a problem with my ODBC loaded tables on Power BI. I can't use the Power Query Editor on these tables, because there is some kind of error:
Does this error specifically occur with ODBC or is there a way to resolve this?
Maybe worth to mention that the ODBC was not set up by me and is being administered by a third party.
Thanks in advance for helping me out!
DM0010
v-yalanwu-msft
Hi, @DM0010 ;
Try to configure both user DSN and System DSN for this connection in the ODBC data source, and create DSN and test in both 32-bit/64-bit ODBC data source.
Solved: ODBC: ERROR [IM002] [Microsoft][ODBC Driver Manage... - Microsoft Power BI Community
error [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified wh...
In additional,
A 32-bit driver cannot work with a 64-bit App.
In your specific case you'd better change the MySQl ODBC Driver version from 32-bit to 64-bit.
Hence PBI, ODBC Oracle and ODBC MySQL will be in 64-bit versions
Community Support Team _ Yalan Wu
v-yalanwu-msft
Hi, @DM0010 ;
In additional,
May Power BI Update Carousel
Fabric SQL PBI Data Days
Data Days 2026 coming soon!
