Hello everyone,
i receive data of weighting process, the data i receive are as following:
| Component | Batch | Weight |
| A | 12 | 0,2 |
| B | 13 | 1 |
| C | 14 | 3 |
| D | 15 | 2,1 |
| E | 16 | 0,9 |
| E | 16 | 1 |
| D | 15 | 2,2 |
| C | 14 | 3,1 |
| B | 13 | 1 |
| A | 12 | 0,2 |
I want to add a column to count "weight procedure", like this, so when all components of the mixture added to the weighting process, it should increase the value:
| Component | Batch | Weight | Weight procedure |
| A | 12 | 0,2 | 1 |
| B | 13 | 1 | 1 |
| C | 14 | 3 | 1 |
| D | 15 | 2,1 | 1 |
| E | 16 | 0,9 | 1 |
| E | 16 | 1 | 2 |
| D | 15 | 2,2 | 2 |
| C | 14 | 3,1 | 2 |
| B | 13 | 1 | 2 |
| A | 12 | 0,2 | 2 |
Now there is a problem. Sometimes, it could happen, when one batch of a component is not sufficient for required amount, there are used 2 batches for example like this:
| A | 12 | 0,2 |
| B | 13 | 1 |
| C | 14 | 3 |
| D | 15 | 1 |
| D | 15-2 | 1,1 |
| E | 16 | 0,9 |
| E | 16 | 1 |
| D | 15 | 2,2 |
| C | 14 | 3,1 |
| B | 13 | 1 |
| A | 12 | 0,2 |
As you can see, there are in total 2 issues:
1) My data are alternating beginning to count from component A -> component E and then from component E -> component A before it repeats.
2) Sometimes there are not only 5 batches in one mix but 6 or 7, so i can´t simply count to 5 until i add +1 to "Weight procedure" number.
Is there a clever way to add a column to count the number of weight procedure, when all components are added?
Looking forward to your ideas.
Kind regards,
Simon
Here is a sample code you can start from...
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("ZVBJEsAgCPsLZ2UqLu212ysc//+NijpW8cKQIAkxRjhBgaFcNiRIKsLFhOVS4M2dy8UW+DD0fVqh5n2DlXq5D0XQD4SuHm6k7GDb18zsQ23+39F8xJ1Ljko02+WNFxoo0hLuIu+UpmgESYgVPGZNI3+Y2nfMd6UP", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Component = _t, Batch = _t, Weight = _t]),
set_types = Table.TransformColumnTypes(Source,{{"Component", type text}, {"Batch", type text}, {"Weight", type number}}),
add_zero_index = Table.AddIndexColumn(set_types, "Index", 0, 1, Int64.Type),
add_isSequenced = Table.AddColumn(add_zero_index, "isSequenced", each try if Number.Abs(Number.From(add_zero_index[Batch]{[Index]+1}) - Number.From([Batch])) = 1 then "yes" else "no" otherwise null, type text),
add_local_group_values = Table.AddColumn(add_isSequenced, "Local Group Values", each if ([Component] = "A" or [Component] = "E") and [isSequenced] = "yes" then [Component] else null, type text),
fill_down = Table.FillDown(add_local_group_values,{"Local Group Values"}),
remove_columns = Table.RemoveColumns(fill_down,{"Index", "isSequenced"}),
local_grouping = Table.Group(remove_columns, {"Local Group Values"}, {{"All Rows", each _, type table [Component=nullable text, Batch=nullable text, Weight=nullable number, #"Local Group Values"=text]}}, GroupKind.Local),
add_weight_procedure = Table.AddIndexColumn(local_grouping, "Weight Procedure", 1, 1, Int64.Type),
expand_columns = Table.ExpandTableColumn(add_weight_procedure, "All Rows", {"Batch", "Component", "Weight"}, {"Batch", "Component", "Weight"}),
remove_local_group = Table.RemoveColumns(expand_columns,{"Local Group Values"}),
reorder_columns = Table.ReorderColumns(remove_local_group,{"Component", "Batch", "Weight", "Weight Procedure"})
reorder_columns
Starting with this data...
It transforms into...
Proud to be a Super User! | |
Hi @SimonSchoutz,
Hi @SimonSchoutz ,
Hi @SimonSchoutz, what about this?
Output
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("dY87EsMwCETvQk3BT8Iq7cgjV7mAxve/RoScJplRB/uWBXqHHRCqKBVNPsoEN3Y4Qjy9EZWsZTSCOsErQBM7nLOEi5EnqF/QnNgj06Z8jmqvbxI2Jgp/XujpJ+Zysi1iFNNqMa1OfSb+HrOQ7w8=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Component = _t, Batch = _t, Weight = _t]),
ChangedType = Table.TransformColumnTypes(Source,{{"Weight", type number}}, "en-US"),
CompDistinct = List.Buffer(List.Distinct(ChangedType[Component])),
Comp = List.Buffer(ChangedType[Component]),
GenWeightProcedure = List.Generate(
()=> [ x = 0, y = {Comp{x}}, z = false, w = false, q = 1 ],
each [x] < List.Count(Comp),
each [ x = [x]+1,
y = if z then {Comp{x}} else [y] & {Comp{x}},
z = List.ContainsAll([y] & {Comp{x}} , CompDistinct),
w = if z then true else false,
q = if [w] then [q]+1 else [q] ],
each [q] ),
Merged = Table.FromColumns(Table.ToColumns(ChangedType) & {GenWeightProcedure}, Value.Type(Table.FirstN(ChangedType, 0) & #table(type table[Weight Procedure=Int64.Type], {})))
Merged
reorder_columns
Wow, thank you for your quick support. I think i got an issue with the sequence section.
Batch could also contain letters and not only numbers for example:
| A | D2309357 | 5 |
| B | DE7G009639 | 2,3 |
| C | DG24B7162B | 1,1 |
| D | DG24G7017A | 4 |
| E | ADN0214100 | 16 |
| E | ADN0214100 | 15 |
| D | DG24H7048A | 3,5 |
| C | DG24B7162B | 1,0 |
| B | DE7G009639 | 2,5 |
| A | D2309357 | 4,5 |
I think, this breaks the seqeuence method listed above, right?
One thing, which might help in building a sequence, component E has always the biggest weight number. So maybe it makes sense to add up the weight numbers until i reach a certain threshhold, in this case (5+2,3+1,1+4+16 = ) 28,4, so if value is e.g. >25, next measurement should be next weight procedure, right?
It does break the sequence.
What would the Batch number look like there were two or more batches in a single sequence? In your first example they were differentiated with '-2' etc. Would that hold true with your new example data?
Sorry for my late reply. You can see in the post above your comment an example for real batch numbers. For example component D uses batch number DG24G7017 and DG24H7048A. There is not only a "-2" added to the batch number. Sorry for confusion.
What is your expected result given the sample data?
Result should look like this:
| A | 12 | 0,2 | 1 |
| B | 13 | 1 | 1 |
| C | 14 | 3 | 1 |
| D | 15 | 1 | 1 |
| D | 15-2 | 1,1 | 1 |
| E | 16 | 0,9 | 1 |
| E | 16 | 1 | 2 |
| D | 15 | 2,2 | 2 |
| C | 14 | 3,1 | 2 |
| B | 13 | 1 | 2 |
| A | 12 | 0,2 | 2 |
