Power query row to column. Pls help
I have this as data.
| clientid | Name | Email and Role |
| C0003 | XYZ | [email protected];Informed,Accountable |
| C0003 | abc | [email protected];Informed,Accountable |
| C0003 | Bikas | [email protected];Responsible |
| C0004 | Ram | [email protected];Informed |
| C0007 | Patil | [email protected];Informed,Accountable |
| C0007 | Padma | [email protected];Responsible |
I want the data in the following format pls help -
| clientid | Name | Email and Role | Name | Email and Role | Name | Email and Role |
| C0003 | XYZ | [email protected];Informed,Accountable | abc | [email protected];Informed,Accountable | Bikas | [email protected];Responsible |
| C0004 | Ram | [email protected];Informed | ||||
| C0007 | Patil | [email protected];Informed,Accountable | Padma | [email protected];Responsible |
- wdx223_Daniel
NewStep= Table.Combine(Table.Group(PreviousStepName,"clientid",{"n",each #table({"cliendid"}&List.TransformMany({1..Table.RowCount(_)},each List.Skip(Table.ColumnNames(_)),(x,y)=>y&" - "&Text.From(x)),{List.Combine(Table.ToList(_,List.Skip))})})[n])
- AnonymousNot applicable
Thanks. How to add this to current formula? pls help
Current formula as in advanced editor is -
Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content],
#"Added Custom" = Table.AddColumn(Source, "Custom", each [Column1.descp.1]&","&[Column1.descp.2]&","&[Column1.descp.3]),
#"Added Custom1" = Table.AddColumn(#"Added Custom", "Custom.1", each Text.Combine(
List.Select(
{ [Column1.descp.1], [Column1.descp.2], [Column1.descp.3] },
each _ <> ""
#"Removed Columns" = Table.RemoveColumns(#"Added Custom1",{"Custom", "Column1.descp.5", "Column1.descp.4", "Column1.descp.3", "Column1.descp.1", "Column1.descp.2", "Column2", "Column1", "Column1.isgroupinfo", "Column1.iscommu", "Column1.rtype", "Column1.id"}),
#"Added Custom2" = Table.AddColumn(#"Removed Columns", "Custom", each [Column1.info]&";"&[Custom.1]),
#"Removed Columns1" = Table.RemoveColumns(#"Added Custom2",{"Column1.info", "Custom.1"}),
#"Renamed Columns" = Table.RenameColumns(#"Removed Columns1",{{"Column1.clientid", "clientid"}, {"Column1.attri", "Name"}, {"Custom", "Email and Role"}})
#"Renamed Columns"how should i modify this?
- wdx223_Daniel
List.Select(
each _ <> ""
#"Renamed Columns" = Table.RenameColumns(#"Removed Columns1",{{"Column1.clientid", "clientid"}, {"Column1.attri", "Name"}, {"Custom", "Email and Role"}}),NewStep= Table.Combine(Table.Group(#"Renamed Columns","clientid",{"n",each #table({"cliendid"}&List.TransformMany({1..Table.RowCount(_)},each List.Skip(Table.ColumnNames(_)),(x,y)=>y&" - "&Text.From(x)),{List.Combine(Table.ToList(_,List.Skip))})})[n])
NewStep
- Jakinta
Solution Sage
You can try with these steps
Group = Table.Group(PreviousStep, {"clientid"}, {{"A", each let l = List.Union (Table.ToRows( Table.RemoveColumns(_, {"clientid"}))) in Text.Combine(l, "//"), type text }}), Split = Table.SplitColumn(Group, "A", Splitter.SplitTextByDelimiter("//", QuoteStyle.Csv)), Count = {1..Number.RoundUp ((List.Count( Table.ColumnNames(Split)) - 1 )/2,0)}, Cols = List.Skip (Table.ColumnNames (Source)), NewNames = {Table.ColumnNames (Source){0}} & List.Union ( List.Zip ({ List.Transform( Count, each Cols{0} & "_" & Text.From(_) ), List.Transform( Count, each Cols{1} & "_" & Text.From(_) ) })), Custom = Table.RenameColumns ( Split, List.Zip ( { Table.ColumnNames(Split) , NewNames }) ), ReplacedNulls = Table.ReplaceValue(Custom,null,"",Replacer.ReplaceValue,Table.ColumnNames (Custom)) in ReplacedNulls
