rafterse
Power query create a column syntax - help
I'm getting this error, what am i missing.
summary
i want to create a colum that looks at 1 column for text.contains "XXXXX" and the start of another column doesn't start with text "YYYYY_______" then return a result
AlienSx
Table.AddColumn(
    your_table,
    "LHRR",
    each
        if Text.Contains([a], "xxxx") and
        not Text.StartsWith([b], "yyyy")
        then "LHRR"
        else "notLHRR"
rafterse
ledgend. thanks so much
Hi @rafterse  If @AlienSx 's solution helps, you can accept that reply as Solution. Thanks.
AlienSx
Table.AddColumn(
    your_table,
    "LHRR",
    each
        then "LHRR"
        else "notLHRR"
