ojhaashok
Power Query running difference
How can I calculare the running difference in "Power Query". In fact I need to do in Dataflow of fabric so asking Power Query.
I have column values Asset, AsOfDate, Name and Value data. I added Row ID just so my example is clear. I need to calculare Depreciare column value in Power Query. I don't know how I can do that.
The story is in 1/1/2024 someone got new laptop of $2000, and the value of laptop goes down $50 every future months. At one point value will be zero but below is small example to find a solution.
Row IDAssetAsOfDateNameValueDepreciate
1Laptop1/1/2024Price20000
1Laptop1/1/20242/1/2024501950
1Laptop1/1/20243/1/2024501900
1Laptop1/1/20244/1/2024501850
1Laptop1/1/20245/1/2024501800
2Desk1/1/2024Price5000
2Desk1/1/20242/1/202410490
2Desk1/1/20243/1/202410480
2Desk1/1/20244/1/202410470
2Desk1/1/20245/1/202410460
3TV1/1/2024Price15000
3TV1/1/20242/1/2024301470
3TV1/1/20243/1/2024301440
3TV1/1/20244/1/2024301410
3TV1/1/20245/1/2024301380
Thank you,
AK
2 ACCEPTED SOLUTIONS
ronrsnfld
In Power Query, you can use List.Generate to create a list of the values, then add that as a column. You would do this as an aggregation within  the Table.Group function.
You would also need to manually zero the first entry to get your desired result.
You can group by Asset eliminating the need for the row column.
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45W8kksKMkvUNJRMtQ31DcyMDIBMgOKMpNTgbSRgYGBUqwOdkVGCKYpblXGRKkyIUqVKYYql9TibOxONzXApQLJ3Ya41BgTocaECDWmGGpCwrC71xDmYHQFSM41xq7CmKAKE4IqTFFVxAIA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Asset = _t, AsOfDate = _t, Name = _t, Value = _t]),
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"Asset", type text}, {"AsOfDate", type date}, {"Name", type text}, {"Value", Int64.Type}}),
    #"Grouped Rows" = Table.Group(#"Changed Type", {"Asset"}, {
        {"Deprec", (t)=> let
            #"Deprec List" =
                 List.Generate(
                    ()=>[d=t[Value]{0}, idx=0],
                    each [idx] < Table.RowCount(t),
                    each [d=[d]-t[Value]{[idx]+1}, idx=[idx]+1],
                    each [d]),
            #"Zero First" = List.ReplaceRange(#"Deprec List",0,1,{0}),
            #"Add as Column" = Table.FromColumns(
                Table.ToColumns(t)
                & {#"Zero First"},
                type table [Asset=nullable text, AsOfDate=nullable date, Name=nullable text, Value=nullable number, Depreciation=nullable number])
            #"Add as Column",
    #"Expanded Deprec" = Table.ExpandTableColumn(#"Grouped Rows", "Deprec", {"AsOfDate", "Name", "Value", "Depreciation"})
    #"Expanded Deprec"
slorin
Hi, @ojhaashok
another solution just with Table.NestedJoin
ChangedType = Table.TransformColumnTypes(Source,{{"Asset", type text}, {"AsOfDate", type date}, {"Name", type text}, {"Value", Int64.Type}}),
Month = Table.AddColumn(ChangedType, "Month", each try Date.From([Name]) otherwise null),
Join = Table.NestedJoin(Month, {"Asset", "AsOfDate"}, #"Month", {"Asset", "AsOfDate"}, "Join", JoinKind.LeftOuter),
Depreciate = Table.AddColumn(Join, "Depreciate",
(x) => x[Join]{[Name ="Price"]}[Value] - List.Sum(Table.SelectRows(x[Join], each [Month]<=x[Month])[Value]))
Depreciate
Stéphane
slorin
Hi, @ojhaashok
Depreciate
Stéphane
dufoq3
Hi @ojhaashok, anothere solution (similar to @ronrsnfld, but with List.Accumulate)
    fn_Depreciate =
        (myTable as table)=>
            // Tbl = GroupedRows{[Asset="Laptop"]}[All],
            Tbl = myTable,
            ValueBuffer = List.Buffer(Tbl[Value]),
            AccumulatedDepreciate = List.Accumulate(
                { 0..List.Count(ValueBuffer)-1 },
                (s,c)=> s & { if c = 0 then 0 else if c = 1 then ValueBuffer{0} - ValueBuffer{c} else s{c-1} - ValueBuffer{c} } ),
            ToTable = Table.FromColumns(Table.ToColumns(Tbl) & {AccumulatedDepreciate}, Value.Type(Tbl & #table(type table[Depreciate = number],{})))
            ToTable,
    GroupedRows = Table.Group(ChangedType, {"Asset"}, {{"All", fn_Depreciate, type table}}),
        CombinedAll
Hi @ojhaashok ,
@ronrsnfld Thanks for your concern about this case!
Another solution:
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("jc+rCoBAEIXhd9ksOJedNzAaDGKRDSIGMSjq++MUUdl1mXT+8JXT9w5d4ephO9dNA0ssCchrNvs8TroEAC4U/5CelLxks/RmKZEkzWo6lvQdgZx6fcGcY6PzRieRY822S3/A+0QKvS7wv2KT8iYlXxUu", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Row ID" = _t, Asset = _t, AsOfDate = _t, Name = _t, Value = _t]),
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"Row ID", Int64.Type}, {"Asset", type text}, {"AsOfDate", type date}, {"Name", type text}, {"Value", Int64.Type}}),
    #"Grouped Rows" = Table.Group(#"Changed Type", {"Row ID"}, {{"Count", each Table.AddIndexColumn(_, "Index", 1, 1, Int64.Type)}}),
    #"Expanded Count" = Table.ExpandTableColumn(#"Grouped Rows", "Count", {"Asset", "AsOfDate", "Name", "Value", "Index"}, {"Asset", "AsOfDate", "Name", "Value", "Index"}),
    #"Added Custom" = Table.AddColumn(#"Expanded Count", "Custom", each
        currentID = [Row ID],
        currentIndex = [Index]
        Table.SelectRows(#"Expanded Count", each ([Row ID] = currentID and [Name] = "Price")){0}[Value] -
        (if [Name] = "Price" then
        [Value]
        else
        List.Sum(
            Table.SelectRows(
                #"Expanded Count",
                each [Row ID] = currentID and [Index] <= currentIndex and [Index] <> 1
            )[Value]
    #"Added Custom"
And the final output is as below:
Dino Tao
If this post helps, then please consider Accept both of the answers as the solution to help the other members find it more quickly.
ronrsnfld
            #"Deprec List" =
                 List.Generate(
                    each [d]),
                Table.ToColumns(t)
                & {#"Zero First"},
            #"Add as Column",
    #"Expanded Deprec"
July Power BI Update Carousel
60 days of Data Days Carousel
Data Days 2026
