jo123456
3 years agoHelper I
Power Query help with finance
I have a table like the one below
region industry year value
North America farming 2019 400
Europe carpentry 2020 600
North America farming 2020 700
Europe capentry 2021 800
North America farming 2021 400
In dax
FYQ1 =
VAR CurrentYear = 'table'[Year]
VAR EarlierYear = CurrentYear - 1
VAR EarlierYearValue =
CALCULATE(
SUM('table'[value]),
FILTER(
'table',
'table'[region] = EARLIER( 'table'[region]) &&
'table'[industry] = EARLIER( 'table'[industry]) &&
'table'[Year] = EarlierYear
EarlierYearValue * 0.25
to get a desired column value where if region,industry match then I need last year's value to be multiplied with .25 to return a new value. How do I do this in powerQuery without this error cyclic reference was encountered during evaluation? Please help
- Anonymous3 years ago
Hi jo123456
You can put the following code to advanced editor in power query
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45W8ssvKslQ0lFyzE0tykxOVEhLLMrNzEsHihgZGFoCKRMDA6VYnWgl19Ki/IJUoEByYlFBal5JUSVYjZEBkDKDqsFnGFihOQHDDIGUBTGGGcJcFgsA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [region = _t, industry = _t, year = _t, value = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"region", type text}, {"industry", type text}, {"year", Int64.Type}, {"value", Int64.Type}}), Custom1 = Table.AddColumn(#"Changed Type","Custom",each Table.SelectRows (#"Changed Type",(x) =>x [region]=[region] and x[industry]=[industry] and x[year]=[year]-1)), #"Expanded Custom" = Table.ExpandTableColumn(Custom1, "Custom", {"value"}, {"value.1"}), #"Added Custom" = Table.AddColumn(#"Expanded Custom", "FYQ1", each [value.1]*0.25), #"Removed Columns" = Table.RemoveColumns(#"Added Custom",{"value.1"}), #"Sorted Rows" = Table.Sort(#"Removed Columns",{{"region", Order.Ascending}}) in #"Sorted Rows"Output
Best Regards!
Yolo Zhu
- jo123456Helper I
note my current one is in dax
- AnonymousNot applicable
Hi jo123456
Best Regards!
Yolo Zhu
