I'm new to Power BI and my question is basic.
I need to connect Power BI desktop to a service for which a pre-designed connector is not available. Then I need to make a dashboard and get it published with refresh capability. My research shows I should use an ODBC driver and then gata dateway to get the dashboard refreshed.
Is it the right way? If so, what are the steps I need to take? I would really appreciate it if you can breeak the process down.
Hi @Anonymous ,
Please follow the steps below.
1. Get data in power bI desktop with the ODBC connector and create your report and publish it to Power BI Service.
2. Assuming that you have installed the data gateway, you could add your data souce in the gateway. Please refer to this guide docuemnt. If you have not installed the gateway, please follow this article.
3. Edit your credential and set schedule refresh under Setting>> Dataset in Power BI Service.
If you still need help, please feel free to ask.
Cherry
Hi @Anonymous ,
Have you solved your problem?
If you have solved, please always accept the replies making sense as solution to your question so that people who may have the same question can get the solution directly.
Cherry
Cherry,
Thanks for the links. Big help. I will start the project next week and probably ask more questions 🙂
Hi @Anonymous ,
Cherry
Hi, should I use gateways to connect my Firebase data to PowerBI?
| 19 | |
| 9 | |
| 8 | |
| 7 | |
| 6 |
