2 years agoPower BI Calculations - HELP
Each of the red numbers are assigned to a specific supplier, the blue numbers are the target mix for the different suppliers. I need to subtract these values based on the supplier name. I have a large set of data and they are grouped by month and supplier.
Essentially I need to do:
31%-39%
22%-23%
48%-38%
- AnonymousNot applicable
Hi @tholland
If you have a one-to-one relationship between the two tables you can just subtract them. If it is a one-to-many or many-to-many relationship then it is more difficult, please provide some sample data so that I can test it.
Dino Tao- Syndicate_Admin
It is not that I need to subtract every value though. I need to subtract certain suppliers (red) from their target mix (blue).
