2 years agoPower BI Calculations - HELP
Each of the red numbers are assigned to a specific supplier, the blue numbers are the target mix for the different suppliers. I need to subtract these values based on the supplier name. I have a larg...
2 years agoNot applicable
Hi @tholland
If you have a one-to-one relationship between the two tables you can just subtract them. If it is a one-to-many or many-to-many relationship then it is more difficult, please provide some sample data so that I can test it.
Dino Tao
- Syndicate_Admin2 years ago
It is not that I need to subtract every value though. I need to subtract certain suppliers (red) from their target mix (blue).
