kamranmumtaz02's avatar
kamranmumtaz02
3 years ago
Need help with power query unpivoting
Hello all,
Please check out the below screenshot of the normal table (there is an unnecessary break in each machine table) that I am getting from my colleague "DATA" along with the "DESIRED RESULT" that I want as the final result.
The data is in a regular excel table form and it would be time-taking to make official tables of each machine (a total of 16 machines) every time. I am looking forward to a code that will work if I convert the complete data into one sheet to save time by not making each machine an official excel table every time, Could anyone provide a code?
  • Hi kamranmumtaz02 ,
    According to your description, I try my best to reproduce your problem. I create sampe like this:
    Here's my solution.
    1.Add a custom column in MACHINE1, MACHINE2, MACHINE3 tables separately like this:
    2.Select Merge Queries>Merge Queries as New.
    3.Filter out the blank and title rows.
    Get the result:
    I attach my sample below for your reference.
    Community Support Team _ kalyj
    If this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
    • kamranmumtaz02's avatar
      kamranmumtaz02
      @v-kal
      Thank you for your efforts but the provided data is sample data, there are more than 15 machines, and I cannot make them table each time, which is why I asked if is there a way to make the complete data a table and then convert it into one data. I am new to power query but can make one data from multiple sheets, but this is something challenging for me.
  • KT_Bsmart2gethe's avatar
    KT_Bsmart2gethe
    Icon for Impactful Individual rankImpactful Individual
    Hi kamranmumtaz02 ,
    I assumed the input is as below:
    //Import file
    Source = Excel.Workbook(File.Contents("Filepath ....."), null, true),
    Sheet1_Sheet = Source{[Item="Sheet1",Kind="Sheet"]}[Data],
    //Below code is the solution:
        TableToColumns = Table.ToColumns(Sheet1_Sheet),
        SearchKeyword_Machine = List.Select(List.Transform(List.Combine(TableToColumns), Text.From), each Text.StartsWith(_, "Machine", Comparer.OrdinalIgnoreCase)),
        MachineCount = List.Count(SearchKeyword_Machine),
        RemovedNulls = List.Transform(TableToColumns, each List.RemoveNulls(_)),
        RemovedEmptyList = List.Select(RemovedNulls, each not List.IsEmpty(_)),
        ListCleanedUp = List.Transform(RemovedEmptyList, each List.Select(List.Transform(_, Text.From), each not Text.Contains(_, "Machine"))),
        RowNum = List.Numbers((MachineCount-1)*3,MachineCount,-3),
        InsertMachineNum = List.Accumulate({0..List.Count(RowNum)-1}, ListCleanedUp, (x,y)=> List.InsertRange(x,RowNum{y},{{"MACHINE #", SearchKeyword_Machine{y}}})),
        SplitLists = List.Split(InsertMachineNum, MachineCount+1),
        TableFromColumns = List.Transform(SplitLists, each Table.FromColumns(_)),
        CombineTables = Table.Combine(TableFromColumns),
        #"Promoted Headers" = Table.PromoteHeaders(CombineTables, [PromoteAllScalars=true]),
        #"Filtered Rows" = Table.SelectRows(#"Promoted Headers", each ([DATE] <> "DATE")),
        #"Filled Down" = Table.FillDown(#"Filtered Rows",{"MACHINE #"})
        #"Filled Down"
    Output:
    Regards
    KT
