Don't miss your chance to take exam DP-600 or DP-700 on us!
Request nowLearn from the best! Meet the four finalists headed to the FINALS of the Power BI Dataviz World Championships! Register now
Apologies for multiple posts as my previous one was tagged as spammed and I could not reply.
Is there anyway to transform the sample data into the second table below. Basically, some employees need to split based on a ratio to other cost centres (B, C, D or E). Using Staff B as an example, his costs should be split across cost centres C & D while no costs should remain at cost centre B.
| Account Code | Account Name | Amount | Cost Centre | Names | B | C | D | E |
| 446 | Salary | 1000 | A | Staff A | ||||
| 447 | Annual Leave | 100 | A | Staff A | ||||
| 449 | Superannuation | 100 | A | Staff A | ||||
| 446 | Salary | 2000 | B | Staff B | 1000 | 1000 | ||
| 447 | Annual Leave | 200 | B | Staff B | 100 | 100 | ||
| 449 | Superannuation | 100 | B | Staff B | 50 | 50 | ||
| 446 | Salary | 2500 | C | Staff C | 2000 | 500 | ||
| 447 | Annual Leave | 100 | C | Staff C | 80 | 20 | ||
| 449 | Superannuation | 100 | C | Staff C | 80 | 20 |
Desired Output:
| Cost Centre | Account Code | Account Name | Net |
| A | 446 | Salary | 1000 |
| A | 447 | Annual Leave | 100 |
| A | 449 | Superannuation | 100 |
| B | 446 | Salary | 0 |
| B | 447 | Annual Leave | 0 |
| B | 449 | Superannuation | 0 |
| C | 446 | Salary | 1000 |
| C | 447 | Annual Leave | 100 |
| C | 449 | Superannuation | 50 |
| D | 446 | Salary | 3000 |
| D | 447 | Annual Leave | 180 |
| D | 449 | Superannuation | 130 |
| E | 446 | Salary | 500 |
| E | 447 | Annual Leave | 20 |
| E | 449 | Superannuation | 20 |
Thank you in advance
You need to modify your source table to include the destination for all rows.
And then you can remove all the redundant columns
Having the split in columns is generally bad practice for Power BI (common for Excel data) - maintenance red flag.
Anyway, here is the transform :
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMjExU9JRCk7MSSyqBDIMDQwMgJQCCo7VAakzB7Id8/JKE3MUfFITy1IhqnEotgQZWlqQWpQI0lGSmZ+HVzmKG6ByUKfAXYTTFQj1SHbgcQZUvakBjMDnChA2gjjBFEgScgQIWxiA9RDhBBTVsQA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Account Code" = _t, #"Account Name" = _t, A = _t, B = _t, C = _t, D = _t, E = _t]),
#"Unpivoted Other Columns" = Table.UnpivotOtherColumns(Source, {"Account Code", "Account Name"}, "Cost Centre", "Net"),
#"Changed Type" = Table.TransformColumnTypes(#"Unpivoted Other Columns",{{"Net", Int64.Type}}),
#"Grouped Rows" = Table.Group(#"Changed Type", {"Cost Centre", "Account Code", "Account Name"}, {{"Net", each List.Sum([Net]), type text}}),
#"Sorted Rows" = Table.Sort(#"Grouped Rows",{{"Cost Centre", Order.Ascending}, {"Account Code", Order.Ascending}})
#"Sorted Rows"
How to use this code: Create a new Blank Query. Click on "Advanced Editor". Replace the code in the window with the code provided here. Click "Done". Once you examined the code, replace the Source step with your own source.
#"Sorted Rows"
| 10 | |
| 9 | |
| 7 | |
| 5 | |
| 5 |
