Learn moreLevel up your Power BI skills this month - build one visual each week and tell better stories with data! Get started
Hi team, I am currently working on my borganizational project and i am trying to create new measure for my database using below query. However i can't able to add new measure due to syntax error. Can someone please help me.
Problem is about second quote in the formula for NA. In place of "NA” use "NA"
Hence following formula would work
Risk Level =
var Impact = AVERAGE(Output[RiskImpact])
var Likelihood = AVERAGE(Output[RiskLikelihood])
return
SWITCH(TRUE() ,
Impact > 0 && Impact <= 2 && Likelihood > 0 && Likelihood <=4 , "LOW" ,
Impact > 0 && Impact <= 2 && Likelihood > 4 && Likelihood <=5 , "MEDIUM" ,
Impact > 2 && Impact <= 3 && Likelihood > 0 && Likelihood <=4 , "MEDIUM" ,
Impact > 2 && Impact <= 3 && Likelihood > 4 && Likelihood <=5 , "HIGH" ,
Impact > 3 && Impact <= 4 && Likelihood > 0 && Likelihood <=3 , "MEDIUM" ,
Impact > 3 && Impact <= 4 && Likelihood > 3 && Likelihood <=5 , "HIGH" ,
Impact > 4 && Impact <= 5 && Likelihood > 0 && Likelihood <=1 , "MEDIUM" ,
Impact > 4 && Impact <= 5 && Likelihood > 1 && Likelihood <=5 , "HIGH",
"NA")
Thank you Vijay. This is works.
