aqeel_shaikh's avatar
aqeel_shaikh
Helper III
2 years ago
Need help in power query
My sample data is
1234-567-AB$C#DEF-123
expectation is to remove bold special character in RED and provide this result "1234-567ABCDEF123"
  • dufoq3's avatar
    dufoq3
    2 years ago
    Check this:
    Result
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("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", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t]),
        Ad_Transformed = Table.AddColumn(Source, "Transformed", each
            [ numbers = {"0".."9"},
              alphabets = {"a".."z", "A".."Z"},
              a = Text.ToList([Column1]),
              b = List.Select(a, each not List.Contains(alphabets & numbers, _)), //Characters to remove/replace
              c = Text.Combine(List.Transform(a, each if List.Contains(b, _) then "-" else _)), //replace other special characters with "-"
              d = Text.Combine(List.RemoveItems(Splitter.SplitTextByDelimiter("-")(c), {""}), "-"), //remove extra dashes
              e = Splitter.SplitTextByCharacterTransition(each true, (x)=> List.Contains(alphabets & numbers, x))(d), //split any|text
              f = Text.Combine(List.Transform(e, each if List.Contains(alphabets, _, (x,y)=> Text.StartsWith(y,x)) then Text.Start(_,1) else _)),
              g = Splitter.SplitTextByCharacterTransition((x)=> List.Contains(alphabets & numbers, x), each true)(f), //split text|any
              h = Text.Combine(List.Transform(g, each if List.Contains(alphabets, _, (x,y)=> Text.EndsWith(y,x)) then Text.End(_,1) else _))
            ][h], type text)
        Ad_Transformed
  • Text.Combine(
        List.Transform(
            Splitter.SplitTextByEachDelimiter({"-"})("1234-567-AB$C#DEF-123"),
            (x) => Text.Combine(List.RemoveItems(Text.ToList(x), {"-", "#", "$"}))
    • aqeel_shaikh's avatar
      aqeel_shaikh
      Helper III
      AlienSx - Hi, I have multiple lines so how i would use the above to get the result...any alternate?
      • AlienSx's avatar
        AlienSx
        Table.TransformColumns to change existing column or Table.AddColumn to create a new one is totally up to you
            lines = #table ({"lines"}, {{"1234-567-AB$C#DEF-123"}, {"1234-567-AB$C#DEF-123"}}),
            rm = Table.TransformColumns(
                lines,
                {"lines", (x) => Text.Combine(
                    List.Transform(
                        Splitter.SplitTextByEachDelimiter({"-"})(x),
                        (y) => Text.Combine(List.RemoveItems(Text.ToList(y), {"-", "#", "$"}))
            rm
