I have some some data available in table format & another data from web source.
Is there any way I can add data from the web source into already available dataset.
basically I want to do,
y = y + x
where x is variable data with time & it should add upon data y.
I need to use use it in Power BI.
Hi @Anonymous
Can you share some sample data for both tables and show with an example based on that data what exactly the requirement is?
Please accept the solution when done and consider giving a thumbs up if posts are helpful. Contact me privately for support with any larger-scale BI needs, tutoring, etc. |
Hi @AlB, actually its a production data for a month, & web source should refresh & should add data to this month data.
