Running Index that Resets based on criteria
Hello i need help with this
I have a Table with many variables, that have Values, this value are evaluated as Status 1 or 0
where 0 = Ok, and 1 is Out of Specification
This variables also have a Criteria for Anomaly Analysis
So i have to make a colum that Count consecutive Status Events that are out of specification
When the counter number reach the same value as the criteria, then it has to show a value 1 in Anomaly Analysis
MONTH | DAY | HOUR | VARIABLE | VALUE | STATUS | CRITERIA | COUNTER | ANOMALY ANALYSIS |
abril | 30 | 00:00 | Acidez en OFLA2 | 123 | 1 | 6 | 1 | |
abril | 30 | 04:00 | Acidez en OFLA2 | 123 | 1 | 6 | 2 | |
abril | 30 | 08:00 | Acidez en OFLA2 | 137 | 1 | 6 | 3 | |
abril | 30 | 12:00 | Acidez en OFLA2 | 121 | 1 | 6 | 4 | |
abril | 30 | 16:00 | Acidez en OFLA2 | 125 | 1 | 6 | 5 | |
abril | 30 | 20:00 | Acidez en OFLA2 | 128 | 1 | 6 | 6 | IA |
mayo | 1 | 00:00 | Acidez en OFLA2 | 123 | 1 | 6 | 7 | |
mayo | 1 | 04:00 | Acidez en OFLA2 | 129 | 1 | 6 | 8 | |
mayo | 1 | 08:00 | Acidez en OFLA2 | 128 | 1 | 6 | 9 | |
mayo | 1 | 18:00 | Acidez OF I2000 | 10 | 1 | 6 | 1 | |
mayo | 2 | 10:00 | Acidez OF I2000 | 2.00 | 1 | 6 | 2 | |
mayo | 2 | 14:00 | Acidez OF I2000 | 2.00 | 1 | 6 | 3 | |
mayo | 2 | 18:00 | Acidez OF I2000 | 1.00 | 1 | 6 | 4 | |
mayo | 2 | 22:00 | Acidez OF I2000 | 1.00 | 1 | 6 | 5 | |
mayo | 3 | 02:00 | Acidez OF I2000 | 1.00 | 1 | 6 | 6 | IA |
mayo | 3 | 06:00 | Acidez OF I2000 | 2.00 | 1 | 6 | 7 |
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WSkwqysxR0lEyNgASBlYGIMoxOTMltUohNU/B383H0QgoYmhkDCKB2EwpVgdNlwlZuixw6jI2x63L0Ai3ZYZ4tJnh1maKW5sRngCxQNGWm1iZDxUgOhCR9OAJQktcenAHIG63GaJq8ndT8DQyAIsYGmDTAzbOAJceI5xaTEjXgttluLQYGZGkBRT4pOswI8InsQA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [MONTH = _t, DAY = _t, HOUR = _t, #" VARIABLE" = _t, VALUE = _t, STATUS = _t, CRITERIA = _t]),
Custom1 = Table.TransformColumns(Source,{{"STATUS",Number.From},{"CRITERIA",Number.From}}),
Custom2 = #table(Table.ColumnNames(Source)&{"COUNTER","ANOMALY ANALYSIS"},List.Accumulate(Table.ToRows(Custom1),{},(x,y)=>let a=List.Last(x,{}) in if y{3}=a{3}? then x&{y&{a{7}+1??1,if a{7}+1=y{6} then "IA" else null}} else x&{y&{if y{5}=0 then null else 1,null}}))
Custom2
Like this?
Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content],
#"Grouped Rows" = Table.Group(Source, {" VARIABLE"}, {{"Details", each _, type table [MONTH=nullable text, DAY=nullable number, HOUR=nullable number, #" VARIABLE"=nullable text, VALUE=nullable number, STATUS=nullable number, CRITERIA=nullable number]}}),
Custom1 = Table.TransformColumns(#"Grouped Rows", {{"Details", each Table.AddIndexColumn(_, "Index", 1,1)}}),
#"Expanded Details" = Table.ExpandTableColumn(Custom1, "Details", {"MONTH", "DAY", "HOUR", " VARIABLE", "VALUE", "STATUS", "CRITERIA", "Index"}, {"MONTH", "DAY", "HOUR", " VARIABLE.1", "VALUE", "STATUS", "CRITERIA", "Index"})
#"Expanded Details"
--Nate
Hello, thanks for the help, i think we aproach to the objetive but still i need to make the counter reset every time the consecutive Status change,
Actually the counter is reseting when the Variable change, but it should also resets when the Status change, i attach an image of the Counter-ToBe
I wast no very clear in this case, the column COUNTER, is the one that i dont know how to make,
If the Status is 1, The COUNTER has to increase from 1 until appear a row with Status 0, then it has to reset the counter, and start from 1 again.
In the formula bar, type:
= Table.AddColumn(SourceOrTableName, "ANOMALY ANALYSIS", each if [VALUE STATUS] = [CRITERIA STATUS] then 1 else null, type number)
--Nate
