Matching Error When Relating Tables in Power Query in Power BI
- 1 year ago
Hi Anonymous It might be due to mismatched data types or inconsistencies in the columns used for the relationship.
Could you please try these for solvingMatch Data Types: Ensure both columns (ID and Index) have the same data type in Power Query.
Trim and Clean Data: Remove extra spaces using "Trim" or Text.Trim().
Check for Duplicates: Remove duplicates in both tables if necessary.
Recreate Index: Ensure index columns are correctly aligned and unique.
After these please recreate and test the relationship in Power BI.
Hi Anonymous,
Thank you Akash_Varuna for the prompt response.
As we haven’t heard back from you, we wanted to kindly follow up to check if the solution provided by the super user resolved your issue.
If our super user response resolved your issue, please mark it as "Accept as solution" and click "Yes" if you found it helpful.
Thanks and regards,
Anjan Kumar Chippa
Hi @changzhe,
We wanted to kindly follow up to check if the solution provided by the super user resolved your issue.
Thanks and regards,
Anjan Kumar Chippa
- v-achippa1 year agoCommunity Support
Hi @changzhe,
If our super user response resolved your issue, please mark it as "Accept as solution" and click "Yes" if you found it helpful.Thanks and regards,
Anjan Kumar Chippa
