Hitu's avatar
Hitu
1 year ago
Left Join using relationship in Power BI direct query mode
Hi All,
We have a requirement to show information from one table and matching information from other 2 tables. The table are suppose A , B and C. A is joined with B with 1 **N and A is Joined with C with 1 **N. We have to achive this using relationship , not using merge query in Power Query.
Please find the screen shoot of mock up data and expected output along with the sample pbix.
Requesting your valuble suggestion
one-to-many relationship
  • You mention Direct Query mode but your data model screenshot shows Import Mode.  Please clarify.
    • Hitu's avatar
      Hitu
      Hi lbendlin
      Thanking you for your response. The actual scenario is for direct query. But to create a sample and share it in the forum , i have created it in import mode.
      • lbendlin's avatar
        lbendlin
        That's not gonna work, as the query behavior will be different. This can only be tested by setting up a Direct Query source like a SQL Server database or a secondary semantic model.
  • v-venuppu's avatar
    v-venuppu
    Hi Hitu ,
    Thank you lbendlin for the prompt response.
    I wanted to check if you had the opportunity to review the information provided and resolve the issue..?Please let us know if you need any further assistance.We are happy to help.
    v-venuppu
    Hi Hitu ,
    May I ask if you have resolved this issue? Please let us know if you have any further issues, we are happy to help.
    v-venuppu
    Hi Hitu ,
    I hope the information provided is helpful.I wanted to check whether you were able to resolve the issue with the provided solutions.Please let us know if you need any further assistance.
