AshishChadda18
Issue with POST API Call in Power BI
Hello everyone,
I’m trying to call an API from Power BI using Power Query M, but I'm encountering issues retrieving the expected publicToken. Here are the details of my situation:
What I’ve Tried:
  1. Constructed the API URL correctly with the master ID.
  2. Used the API key and secret for authentication.
  3. Attempted to extract the publicToken from the response JSON
Current Code:
    MasterID = [master.id],
    apiKey = "1234",
    apiKeySecret = "12345",
    url = "https://a.blazemeter.com/api/v4/masters/" & Text.From(MasterID) & "/public-token?api_key=" & apiKey & "&api_key_secret=" & apiKeySecret,
    response = Web.Contents(url),[
        Content=Text.ToBinary("")
    Source = Json.Document(response),
    publicToken = try Source[result][publicToken] otherwise null
    publicToken
Error Message:
I received the following error:
DataSource.Error: Web.Contents with the Content option is only supported when connecting anonymously.
Details:
    DataSourceKind=Web
AshishChadda18
Thank you for the response @lbendlin . I already tried the above approach but getting the below error:
Error Message:
Details: DataSourceKind=Web
yes, you need to clear the permissions for that connection and choose anonymous.  Power Query has a bad habit of caching credentials, including the wrong ones you chose.
Thanks again, the URL is dynamic but will look into this and update if there's any luck
Hi @AshishChadda18 ,
I reviewed posts in forums and I found that you don't seem to have accepted any reply yet, is your problem solved? As lbendlin said, you could change your credential to see if it works.
Steps to
  1. Go to File/Options and Settings/Data source settings
  2. Select your datasource and click Edit Permissions then Edit Credentials
  3. Select Anonymous and try again
Similar post:
Solved: Web.Contents with the Content option is only suppo... - Microsoft Fabric Community
Stephen Tao
Unfortunately, none of the solutions worked for us. We weren't able to resolve the POST API request. Additionally, it seems that dynamic API calls only work on the desktop version and not on the service version. As a result, we moved our data to an SQL database and fed it into Power BI. Thanks
lbendlin
Please follow the documentation. Use Header, RelativePath and Query parameters. https://learn.microsoft.com/en-us/powerquery-m/web-contents#example-1
