Hi
I have a table A(exist in power bi data model)
| Table A | ||
| ID | Name | Flag |
| 111 | alex | F |
| 222 | padian | T |
| 333 | heyo | T |
| 444 | yope | F |
I want to create a new column 'Flad des' using 'Flag column' by if condition in R SCRIPT, find the below exepected output for your reference.
O/P:
| Table A | |||
| ID | Name | Flag | Flag des |
| 111 | alex | F | FALSE |
| 222 | padian | T | TRUE |
| 333 | heyo | T | TRUE |
| 444 | yope | F | FALSE |
If you could help me it would be helpfull, also please share me the screehot if possible .
Thanks in advance
Hi @Anonymous ,
Please try this:
dataset$Flag_des <- ifelse(dataset$Flag,"True","False")
output <- dataset
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMjQ0VNJRSsxJrQBSbkqxOtFKRkZGQHZBYkpmYh6QEQIWNDY2BrIzUivz4UImJiZAdmV+QSpEaywA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ID = _t, Name = _t, Flag = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"ID", Int64.Type}, {"Name", type text}, {"Flag", type text}}),
#"Run R script" = R.Execute("# 'dataset' holds the input data for this script#(lf) #(lf)dataset$Flag_des <- ifelse(dataset$Flag ,""True"",""False"")#(lf)output <- dataset",[dataset=#"Changed Type"]),
#"""output""" = #"Run R script"{[Name="output"]}[Value]
#"""output"""
Hi @Anonymous ,
Please try this:
output <- dataset
#"""output"""
@Anonymous -
