Vishal
How to do partial comparison b/w 2 columns in power bi, power query, DAX
I have to columns where i need to do comparison. If data in 2 columns are exactly same I am getting correct result but where there are additinal characters, I am not getting desired result. For eg: Following values in 2 columns must match, how to do that? I used contain function in power query, SEARCH function in DAX but not getting result. Need help!!
abc234defqazwsxabc234de
4edcv234edcv
123qaz3qaz
Hi @Vishal
You can put the following code to advanced editor in power query
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WSkxKNjI2SUlNU9JRKkysKi+ugIkoxepEK5mkpiSXAaWAImAWSMzQyBioEigIpmJjAQ==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t, Column2 = _t]),
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"Column1", type text}, {"Column2", type text}}),
    #"Added Custom" = Table.AddColumn(#"Changed Type", "Custom", each Text.Combine(List.Intersect({Text.ToList([Column1]),Text.ToList([Column2])}))),
    #"Added Custom1" = Table.AddColumn(#"Added Custom", "Custom.1", each if [Custom]<>null then "Matched" else "Not Matched")
    #"Added Custom1"
Output
Best Regards!
Yolo Zhu
mlsx4
Memorable Member
Memorable Member
Hi @Vishal
You can do:
= Table.AddColumn(#"PreviousStepName", "IsContained", each Text.Contains( [Column1] , [Column2] , Comparer.OrdinalIgnoreCase ) or Text.Contains( [Column2] , [Column1] , Comparer.OrdinalIgnoreCase ) , type logical)
Hi @mlsx4 ,
Thanks for your reply. Like I mentioned, I have already tried mentioned steps and it is not working.
mlsx4
Memorable Member
Memorable Member
I have tried with your exact example and it is working perfectly.
Have you checked?
Yes, Re-checked. Here is output Table for your reference which is incorrect.
 Col1   Col2
2PC920040YNot in Report
HJ0403QJNot in Report
QJ05Y5E5Not in Report
Not in ReportQ0V114HJ0403QJ
Not in ReportA0V114QJ05Y5E5
Not in ReportP09W001C0F87WG
Not in ReportT0EW00K90D3T2E
Not in ReportPC920040Y
1C0F87WGNot in Report
K90D3T2ENot in Report
Ideally every single value must show status as Matched.
Hi @Vishal
    #"Added Custom1"
Output
Best Regards!
Yolo Zhu
mlsx4
Memorable Member
Memorable Member
Hi @Vishal
I don't know which is your data then, with the only information you have provided, it works for me...
Try to put here more examples, especially what you're trying to compare and fails...
