Alicia_Anderson's avatar
Alicia_Anderson
Resolver I
4 years ago
Help with Power Query custom column with multiple conditions and Text.Contains
I am trying to create a Custom Column in Power Query that looks for a text string in any of three different text fields.  My main issue is that any of the fields may contain a null value and this is causing errors.
For example:  I want to set a new column, IsRelease, to "Y" if Release1 or Release2 or Release3 contains "ABC" else set to "N".
Release1Release2Release3IsRelease
ABCnullnullY
ABCXYZnullY
ABCnullABCY
XYZABCDEFY
nullnullABCY
nullnullnullN
XYZnullXYZN
I need help with the proper way to write this...
If (Release1 Text.Contains "ABC" or
Release2 Text.Contains "ABC" or
Release 3 Text.Contains "ABC" ) then "Y", else "N"
  • BA_Pete's avatar
    BA_Pete
    4 years ago
    Hi Alicia_Anderson ,
    Try this instead:
    try
    if Text.Contains([Release1], "ABC")
        or Text.Contains([Release2], "ABC")
        or Text.Contains([Release3], "ABC")
    then "Y"
    else "N"
    otherwise "N"
    This gives the following output:
    Pete
  • Hi Alicia_Anderson ,
    Try this:
    then "Y"
    else "N"
    Pete
    • Alicia_Anderson's avatar
      Alicia_Anderson
      Resolver I
      That is what I have.  Any row that has a null in one of those fields produces an Error.
        Alicia_Anderson
        Resolver I
        If I change the nulls to "" beforehand, it works without a problem.    Not sure what problems or concerns there may be with doing that.
