Hi everyone, i hope you are doing well...
My problem: I need to know the number of iterations between teams that worked on the same epic.
My data is something like:
| Epic Name | Team |
| A | X |
| A | Y |
| A | Z |
| B | X |
| B | Y |
| C | Z |
| C | Y |
For example:
Epic A i have three teams working together, so the possibilities are: XY, XZ, YX,YZ, ZX, ZY.
Epic B: XY, YX.
Epic C: ZY, YZ
The result would/could be something like (considering the 3 epics above) - this is the output that i want but idk how to do that
| Team | x | y | z |
| x | ---- | 2 | 1 |
| y | 2 | ---- | 2 |
| z | 1 | 2 | ---- |
If anyone solve this problem, could you please send me the editor script ?! that would be great 😃
Hi, @Anonymous ;
Try it.
Source = Table.NestedJoin(Data, {"Epic Name"}, Data1, {"Epic Name"}, "Data1", JoinKind.LeftOuter),
#"Expanded Data1" = Table.ExpandTableColumn(Source, "Data1", {"Team"}, {"Data1.Team"}),
#"Added Conditional Column" = Table.AddColumn(#"Expanded Data1", "Custom", each if [Team] = [Data1.Team] then 1 else null),
#"Filtered Rows" = Table.SelectRows(#"Added Conditional Column", each ([Custom] = null)),
#"Removed Columns" = Table.RemoveColumns(#"Filtered Rows",{"Custom"})
#"Removed Columns"
The final show:
Solved: Generating row value combinations - Microsoft Power BI Community
Permutations table in Power BI or Power Query in Excel – The BIccountant
Solved: Permutations and Combinations - Microsoft Power BI Community
Community Support Team _ Yalan Wu
Hi, @Anonymous ;
Try it.
#"Removed Columns"
The final show:
#"Coluna em pivô" = Table.Pivot(#"Removed Columns", List.Distinct(#"Removed Columns"[Data1.Team]), "Data1.Team", "Epic Name", List.Count),
#"Colunas Reordenadas" = Table.ReorderColumns(#"Coluna em pivô",{"Team", "X", "Y", "Z"})Thanks, your script + script above i can achieve the result wanted! ❤️
