Data loads in Power Query but not Power BI
Hello!
Don't really have SQL experience so I don't know where to begin to find the issue here. Data shows up fine in Power Query, no issues in preview:
Also no issues loading into Excel. But when I try to load into Power BI, I get this message:
Here is the query I'm exporting from Wonderware Query:
SET NOCOUNT ON
DECLARE @StartDate DateTime
DECLARE @EndDate DateTime
SET @StartDate = '20231219 23:26:30.309'
SET @EndDate = '20240320 23:26:30.309'
SET NOCOUNT OFF
SELECT * FROM (
SELECT History.TagName, DateTime, Value, vValue, SourceTag, StartDateTime
FROM History
WHERE History.TagName IN ('P6_M1_Batch_Active_ID')
AND wwRetrievalMode = 'Delta'
AND wwTimeDeadband = 500
AND wwQualityRule = 'Extended'
AND wwVersion = 'Latest'
AND DateTime >= @StartDate
AND DateTime <= @EndDate) temp WHERE temp.StartDateTime >= @StartDate
I'm just pasting this into the SQL Statement area when getting data from the SQL server. This is what Power Query is showing in the advanced editor:
Source = Sql.Database("PLT111", "Runtime", [Query="SET NOCOUNT ON#(lf)DECLARE @StartDate DateTime#(lf)DECLARE @EndDate DateTime#(lf)SET @StartDate = '20231219 23:26:30.309'#(lf)SET @EndDate = '20240320 23:26:30.309'#(lf)SET NOCOUNT OFF#(lf)SELECT * FROM (#(lf)SELECT History.TagName, DateTime, Value, vValue, SourceTag, StartDateTime#(lf) FROM History#(lf) WHERE History.TagName IN ('P6_M1_Batch_Active_ID')#(lf) AND wwRetrievalMode = 'Delta'#(lf) AND wwTimeDeadband = 500#(lf) AND wwQualityRule = 'Extended'#(lf) AND wwVersion = 'Latest'#(lf) AND DateTime >= @StartDate#(lf) AND DateTime <= @EndDate) temp WHERE temp.StartDateTime >= @StartDate", HierarchicalNavigation=true])
Source
What am I missing here? Any help would be greatly appreciated. Thank you!
- Joe_Barry
Solution Sage
Hi andypettit12
Maybe Power BI doesn't support that syntax. I would suggest removing the SET statements and using only Select instead.
Thnaks
Joe
If you found my answer helpful and it solved your issue, please accept as solution
- AnonymousNot applicable
Hi andypettit12
You may try this
DECLARE @StartDate DateTime DECLARE @EndDate DateTime SET @StartDate = '20231219 23:26:30.309' SET @EndDate = '20240320 23:26:30.309' SELECT * FROM ( SELECT History.TagName, DateTime, Value, vValue, SourceTag, StartDateTime FROM History WHERE History.TagName IN ('P6_M1_Batch_Active_ID') AND wwRetrievalMode = 'Delta' AND wwTimeDeadband = 500 AND wwQualityRule = 'Extended' AND wwVersion = 'Latest' AND DateTime >= @StartDate AND DateTime <= @EndDate) temp WHERE temp.StartDateTime >= @StartDateBased on my test, DECLARE and SET are supported. Probably "SET NOCOUNT ON" and "SET NOCOUNT OFF" is not supported.
Jing
If this post helps, please Accept it as Solution to help other members find it. Appreciate your Kudos!
