DanMcG
Connect to Jira with Power BI - code for a function
I recently had to pull some data out of Jira, but couldn't see an easy way to do it natively in Power BI / Power Query, so created a custom function that does it for me based on a JQL statement.
Thought it might be useful to others, so have posted below (for my Jira instance this also works with an auto refresh in the service).
All you need to do is paste the below code into a blank query, then update the jiraDomain to your domain name.
You'll then see a function with 2 parameters, the first wants a JQL statement and the second needs a comma seperated list of the fields that you want from Jira (e.g. "key,Summary,Assignee,Status,Created,Project").
To autheniticate, I've been using basic auth with the username as my company email and the password as a Jira API token.
let Source = (jql as text, optional columnsToKeep as text) =>
    // demo data
    // jql = "project = JSD order by created DESC",
    // columnsToKeep = "key,Summary,Assignee,Status,Created,Project",
    jiraDomain = "https://<your-domain>.atlassian.net",
//get data from Jira using JQL
    getJqlResult = (jql as text)=>
            createQueryTable = Table.FromList(List.Generate(() => 0, each _ < Json.Document(Web.Contents(jiraDomain & "/rest/api/3/search",[RelativePath="?fields=key&jql="&jql]))[total], each _ + 50), Splitter.SplitByNothing(), null, null, ExtraValues.Error),
            addQueries = Table.AddColumn(createQueryTable, "queryLists", each Json.Document(Web.Contents(jiraDomain & "/rest/api/3/search",[RelativePath="?startAt="&Text.From([Column1])&"&jql="&jql]))[issues]),
            removeStartAt = Table.RemoveColumns(addQueries,{"Column1"}),
            expandQueryLists = Table.ExpandListColumn(removeStartAt, "queryLists"),
            expandIssues = Table.ExpandRecordColumn(expandQueryLists, "queryLists", {"id", "key", "fields"}, {"id", "key", "fields"})
            expandIssues,
//get data a list of Jira fields and what the display names are
    getJiraFieldsAndNames = () =>
            jiraFieldNameList = Json.Document(Web.Contents(jiraDomain & "/rest/api/3/field")),
            fieldRecordsToTable = Table.FromList(jiraFieldNameList, Splitter.SplitByNothing(), null, null, ExtraValues.Error),
            expandFieldRecords = Table.ExpandRecordColumn(fieldRecordsToTable, "Column1", {"id", "key", "name"}, {"id", "key", "name"})
            expandFieldRecords,
//create a list of lists that can be used to rename from field system names
    createJiraRenameList = (listOfColumnsToRename as list)=>
            fieldNames = getJiraFieldsAndNames(),
            countNameInstances = Table.AddColumn(fieldNames, "# of Name Columns", each let thisName = [name] in Table.RowCount(Table.SelectRows(fieldNames, each [name] = thisName))),
            checkWhetherFieldRequired = Table.AddColumn(countNameInstances, "renameRequired", each List.Contains(listOfColumnsToRename,[key])),
            filterToRequired = Table.SelectRows(checkWhetherFieldRequired, each ([renameRequired] = true) and ([#"# of Name Columns"] = 1)),
            addRenameListItems = Table.AddColumn(filterToRequired, "renameListItem", each {[key],[name]}),
            createRenameList = Table.Column(addRenameListItems,"renameListItem")
            createRenameList,
//main code
    columnsToKeepAsList =
        if columnsToKeep = null
        then null
        else Text.Split(Text.Replace(Text.Replace(columnsToKeep," ,",","),", ",","),","),
    jqlQueryResult = getJqlResult(jql),
    columnNamesAsList = Table.Column(Record.ToTable(jqlQueryResult{0}[fields]),"Name"),
    expandIssueFields = Table.ExpandRecordColumn(jqlQueryResult, "fields", columnNamesAsList, columnNamesAsList),
    renameColumns = Table.RenameColumns(expandIssueFields,createJiraRenameList(columnNamesAsList)),
    selectColumnsToKeep =
        then renameColumns
        else Table.SelectColumns(renameColumns,columnsToKeepAsList)
    selectColumnsToKeep
in Source
Kalp
Hi there,
Thanks for sharing this
Is there a modification to this code to add custom fields as well?
DanMcG
Hey @Kalp,
I think it should work with custom fields.
If you put in a JQL query that has custom fields included in its definition, that should work.
v-jingzhang
Thank you for your sharing in the community!
PBI Sept Update Carousel
Power BI September 2023 Update
Take a look at the September 2023 Power BI update to learn more.
Learn Live
Learn Live: Event Series
Join Microsoft Reactor and learn from developers.
Dashboard in a day with date
Exclusive opportunity for Women!
Join us for a free, hands-on Microsoft workshop led by women trainers for women where you will learn how to build a Dashboard in a Day!
MPPC 2023 PBI Carousel
Power Platform Conference-Power BI and Fabric Sessions
Join us Oct 1 - 6 in Las Vegas for the Microsoft Power Platform Conference.
