Connect to Jira with Power BI - code for a function
EDIT:
- Please see the 'Accepted Solution' for an updated function that is a bit quicker and works on the V3 API (the original is now depricated).
- Also, there's a few comments below advertising their own integrations. If this is the right move for you, then go ahead, however the function in this solution is pretty much a straight copy / paste (2mins to get going), so it's worth giving it a try first before paying someone.
I recently had to pull some data out of Jira, but couldn't see an easy way to do it natively in Power BI / Power Query, so created a custom function that does it for me based on a JQL statement.
Thought it might be useful to others, so have posted below (for my Jira instance this also works with an auto refresh in the service).
All you need to do is paste the below code into a blank query, then update the jiraDomain to your domain name.
You'll then see a function with 2 parameters, the first wants a JQL statement and the second needs a comma seperated list of the fields that you want from Jira (e.g. "key,Summary,Assignee,Status,Created,Project").
To autheniticate, I've been using basic auth with the username as my company email and the password as a Jira API token.
let Source = (jql as text, optional columnsToKeep as text) =>
// demo data
// jql = "project = JSD order by created DESC",
// columnsToKeep = "key,Summary,Assignee,Status,Created,Project",
jiraDomain = "https://<your-domain>.atlassian.net",
//get data from Jira using JQL
getJqlResult = (jql as text)=>
createQueryTable = Table.FromList(List.Generate(() => 0, each _ < Json.Document(Web.Contents(jiraDomain & "/rest/api/3/search",[RelativePath="?fields=key&jql="&jql]))[total], each _ + 50), Splitter.SplitByNothing(), null, null, ExtraValues.Error),
addQueries = Table.AddColumn(createQueryTable, "queryLists", each Json.Document(Web.Contents(jiraDomain & "/rest/api/3/search",[RelativePath="?startAt="&Text.From([Column1])&"&jql="&jql]))[issues]),
removeStartAt = Table.RemoveColumns(addQueries,{"Column1"}),
expandQueryLists = Table.ExpandListColumn(removeStartAt, "queryLists"),
expandIssues = Table.ExpandRecordColumn(expandQueryLists, "queryLists", {"id", "key", "fields"}, {"id", "key", "fields"})
expandIssues,
//get data a list of Jira fields and what the display names are
getJiraFieldsAndNames = () =>
jiraFieldNameList = Json.Document(Web.Contents(jiraDomain & "/rest/api/3/field")),
fieldRecordsToTable = Table.FromList(jiraFieldNameList, Splitter.SplitByNothing(), null, null, ExtraValues.Error),
expandFieldRecords = Table.ExpandRecordColumn(fieldRecordsToTable, "Column1", {"id", "key", "name"}, {"id", "key", "name"})
expandFieldRecords,
//create a list of lists that can be used to rename from field system names
createJiraRenameList = (listOfColumnsToRename as list)=>
fieldNames = getJiraFieldsAndNames(),
countNameInstances = Table.AddColumn(fieldNames, "# of Name Columns", each let thisName = [name] in Table.RowCount(Table.SelectRows(fieldNames, each [name] = thisName))),
checkWhetherFieldRequired = Table.AddColumn(countNameInstances, "renameRequired", each List.Contains(listOfColumnsToRename,[key])),
filterToRequired = Table.SelectRows(checkWhetherFieldRequired, each ([renameRequired] = true) and ([#"# of Name Columns"] = 1)),
addRenameListItems = Table.AddColumn(filterToRequired, "renameListItem", each {[key],[name]}),
createRenameList = Table.Column(addRenameListItems,"renameListItem")
createRenameList,
//main code
columnsToKeepAsList =
if columnsToKeep = null
then null
else Text.Split(Text.Replace(Text.Replace(columnsToKeep," ,",","),", ",","),","),
jqlQueryResult = getJqlResult(jql),
columnNamesAsList = Table.Column(Record.ToTable(jqlQueryResult{0}[fields]),"Name"),
expandIssueFields = Table.ExpandRecordColumn(jqlQueryResult, "fields", columnNamesAsList, columnNamesAsList),
renameColumns = Table.RenameColumns(expandIssueFields,createJiraRenameList(columnNamesAsList)),
selectColumnsToKeep =
then renameColumns
else Table.SelectColumns(renameColumns,columnsToKeepAsList)
selectColumnsToKeep
in Source
I've made an updated version of the funciton that uses the v3 API (the old one is deprecated). Also runs a bit quicker.
Instructions on how to use this function:
- Copy the code below into a blank query in Power BI (using the advanced editor).
- Update the 'jiraDomain' variable using advanced editor (near the top of the code) with the domain you see when you login to your Jira.
- Generate and save an access token as per Manage API tokens for your Atlassian account | Atlassian Support.
- Invoke the function:
- Put the email address you use to login to Jira in the 'jiraUsername'.
- Put the token from step 3. above into the 'jiraAccessToken'.
- Put a comma demilted list of the fields you want to return in the 'fields' parameter e.g. 'summary, parent, status':
- This list is not case sensitive.
- You can enter custom field names here.
- If you have more than 1 custom field with the same name it will return both fields with the custom field id added as a suffix.
- Add a JQL statement that specifies the issues you want to return.
- If you want to return everything you can enter 'key IS NOT EMPTY'.
let Source = (jiraUsername as text, jiraAccessToken as text, fields as text, jql as text) => let //test data // jiraUsername = jiraUser, // jiraAccessToken = jiraToken, // fields = "id, parent, summary", // jql = "project = kan", //!!!UPDATE THE BELOW VARIABLE!!! jiraDomain = "https://<your-domain>.atlassian.net", //authenication auth = Binary.ToText(Text.ToBinary(jiraUsername & ":" & jiraAccessToken), BinaryEncoding.Base64), //convert_field_names_to_ids function convert_field_names_to_ids = (jiraUsername as text, jiraAccessToken as text, fields as text) => let fieldsConverted = if fields = "id" then "key" else Text.Replace(Text.Replace(fields," ,",","),", ",","), fieldsToGetAsList = Text.Split(Text.Lower(fieldsConverted),","), jiraFieldNameList = Json.Document(Web.Contents(jiraDomain & "/rest/api/3/field", [Headers = [Authorization="Basic " & auth]])), fieldRecordsToTable = Table.FromList(jiraFieldNameList, Splitter.SplitByNothing(), null, null, ExtraValues.Error), expandFieldRecords = Table.ExpandRecordColumn(fieldRecordsToTable, "Column1", {"id", "key", "name"}, {"id", "key", "name"}), addGetFieldCheck = Table.AddColumn(expandFieldRecords, "getField?", each List.Contains(fieldsToGetAsList,Text.Lower([name]))), filterToFieldsToGet = Table.SelectRows(addGetFieldCheck, each ([#"getField?"] = true)), createFieldsString = Text.Combine(Table.Column(filterToFieldsToGet,"id"),",") in createFieldsString, //get_jira_fields_with_rename_lists get_jira_fields_with_rename_lists = (jiraUsername as text, jiraAccessToken as text)=> let auth = Binary.ToText(Text.ToBinary(jiraUsername & ":" & jiraAccessToken), BinaryEncoding.Base64), jiraFieldNameList = Json.Document(Web.Contents(jiraDomain & "/rest/api/3/field", [Headers = [Authorization="Basic " & auth]])), fieldRecordsToTable = Table.FromList(jiraFieldNameList, Splitter.SplitByNothing(), null, null, ExtraValues.Error), expandFieldRecords = Table.ExpandRecordColumn(fieldRecordsToTable, "Column1", {"id", "key", "name"}, {"id", "key", "name"}), #"Added Custom" = Table.AddColumn(expandFieldRecords, "renameList", each if List.Count(let name = [name] in Table.Column(Table.SelectRows(expandFieldRecords, each ([name] = name)),"name"))>1 then {[id],[name] & " (" & [id] & ")"} else {[id],[name]}) in #"Added Custom", //field variables fields_list = Text.Lower(Text.Replace(Text.Replace(fields," ,",","),", ",",")), id_or_key_request = fields_list = "id" or fields_list = "key" or fields_list = "id,key" or fields_list = "key,id", fields_for_query = if fields = null or id_or_key_request then {"key"} else List.RemoveItems(Text.Split(convert_field_names_to_ids(jiraUsername, jiraAccessToken, fields_list), ","), {"issuekey"}), get_issues_list_function = (optional next_page_token as text) => Json.Document(Web.Contents(jiraDomain & "/rest/api/3/search/jql", [ Headers = [ Authorization="Basic " & auth, #"Content-Type" = "application/json" ], Content = Json.FromValue( [ jql = jql, maxResults = 5000, fields = fields_for_query, nextPageToken = next_page_token ] ) ] )), get_issues = List.Generate( () => get_issues_list_function(), each Record.HasFields(_, "issues"), each try get_issues_list_function(_[nextPageToken]) otherwise [] ), #"Converted to Table" = Table.FromList(get_issues, Splitter.SplitByNothing(), null, null, ExtraValues.Error), #"Expanded Column1" = Table.ExpandRecordColumn(#"Converted to Table", "Column1", {"issues"}, {"issues"}), #"Expanded issues" = Table.ExpandListColumn(#"Expanded Column1", "issues"), #"Expanded issues 1" = Table.ExpandRecordColumn(#"Expanded issues", "issues", {"id", "key", "fields"}, {"id", "key", "fields"}), #"Expanded fields" = if id_or_key_request then #"Expanded issues 1" else Table.ExpandRecordColumn(#"Expanded issues 1", "fields", fields_for_query), rename_list = Table.SelectRows(get_jira_fields_with_rename_lists(jiraUser, jiraToken), each List.Contains(fields_for_query, [key]))[renameList], #"Renamed columns" = Table.RenameColumns(#"Expanded fields", rename_list) in #"Renamed columns" in Source
- v-jingzhangCommunity Support
Thank you for your sharing in the community!
- DanMcGFrequent Visitor
let Source = (jiraUsername as text, jiraAccessToken as text, fields as text, jql as text) => let //test data // jiraUsername = jiraUser, // jiraAccessToken = jiraToken, // fields = "id, parent, summary", // jql = "project = kan", //!!!UPDATE THE BELOW VARIABLE!!! jiraDomain = "https://<your-domain>.atlassian.net", //authenication auth = Binary.ToText(Text.ToBinary(jiraUsername & ":" & jiraAccessToken), BinaryEncoding.Base64), //convert_field_names_to_ids function convert_field_names_to_ids = (jiraUsername as text, jiraAccessToken as text, fields as text) => let fieldsConverted = if fields = "id" then "key" else Text.Replace(Text.Replace(fields," ,",","),", ",","), fieldsToGetAsList = Text.Split(Text.Lower(fieldsConverted),","), jiraFieldNameList = Json.Document(Web.Contents(jiraDomain & "/rest/api/3/field", [Headers = [Authorization="Basic " & auth]])), fieldRecordsToTable = Table.FromList(jiraFieldNameList, Splitter.SplitByNothing(), null, null, ExtraValues.Error), expandFieldRecords = Table.ExpandRecordColumn(fieldRecordsToTable, "Column1", {"id", "key", "name"}, {"id", "key", "name"}), addGetFieldCheck = Table.AddColumn(expandFieldRecords, "getField?", each List.Contains(fieldsToGetAsList,Text.Lower([name]))), filterToFieldsToGet = Table.SelectRows(addGetFieldCheck, each ([#"getField?"] = true)), createFieldsString = Text.Combine(Table.Column(filterToFieldsToGet,"id"),",") in createFieldsString, //get_jira_fields_with_rename_lists get_jira_fields_with_rename_lists = (jiraUsername as text, jiraAccessToken as text)=> let auth = Binary.ToText(Text.ToBinary(jiraUsername & ":" & jiraAccessToken), BinaryEncoding.Base64), jiraFieldNameList = Json.Document(Web.Contents(jiraDomain & "/rest/api/3/field", [Headers = [Authorization="Basic " & auth]])), fieldRecordsToTable = Table.FromList(jiraFieldNameList, Splitter.SplitByNothing(), null, null, ExtraValues.Error), expandFieldRecords = Table.ExpandRecordColumn(fieldRecordsToTable, "Column1", {"id", "key", "name"}, {"id", "key", "name"}), #"Added Custom" = Table.AddColumn(expandFieldRecords, "renameList", each if List.Count(let name = [name] in Table.Column(Table.SelectRows(expandFieldRecords, each ([name] = name)),"name"))>1 then {[id],[name] & " (" & [id] & ")"} else {[id],[name]}) in #"Added Custom", //field variables fields_list = Text.Lower(Text.Replace(Text.Replace(fields," ,",","),", ",",")), id_or_key_request = fields_list = "id" or fields_list = "key" or fields_list = "id,key" or fields_list = "key,id", fields_for_query = if fields = null or id_or_key_request then {"key"} else List.RemoveItems(Text.Split(convert_field_names_to_ids(jiraUsername, jiraAccessToken, fields_list), ","), {"issuekey"}), get_issues_list_function = (optional next_page_token as text) => Json.Document(Web.Contents(jiraDomain & "/rest/api/3/search/jql", [ Headers = [ Authorization="Basic " & auth, #"Content-Type" = "application/json" ], Content = Json.FromValue( [ jql = jql, maxResults = 5000, fields = fields_for_query, nextPageToken = next_page_token ] ) ] )), get_issues = List.Generate( () => get_issues_list_function(), each Record.HasFields(_, "issues"), each try get_issues_list_function(_[nextPageToken]) otherwise [] ), #"Converted to Table" = Table.FromList(get_issues, Splitter.SplitByNothing(), null, null, ExtraValues.Error), #"Expanded Column1" = Table.ExpandRecordColumn(#"Converted to Table", "Column1", {"issues"}, {"issues"}), #"Expanded issues" = Table.ExpandListColumn(#"Expanded Column1", "issues"), #"Expanded issues 1" = Table.ExpandRecordColumn(#"Expanded issues", "issues", {"id", "key", "fields"}, {"id", "key", "fields"}), #"Expanded fields" = if id_or_key_request then #"Expanded issues 1" else Table.ExpandRecordColumn(#"Expanded issues 1", "fields", fields_for_query), rename_list = Table.SelectRows(get_jira_fields_with_rename_lists(jiraUser, jiraToken), each List.Contains(fields_for_query, [key]))[renameList], #"Renamed columns" = Table.RenameColumns(#"Expanded fields", rename_list) in #"Renamed columns" in Source- svvelinovNew Member
Hey DanMcG,
Thanks so much for your detailed guidance on connecting Jira to Power BI — everything works like a charm in Power BI Desktop!
The only issue I’m still stuck on is when I publish the report to the Power BI Service. During scheduled or manual refresh, I get the following error:
Web.Contents failed to get contents from rest/api/3/search/jql
Interestingly, the connection to the other Jira endpoint — rest/api/3/field — works perfectly and authenticates without issue.
Do you know what I need to adjust so that both connections authenticate successfully in the Power BI Service?
Thanks in advance for your help!
- TomJerryNew Member
Did you figure this one out? I'm stuck at the same point as you...
- AnonymousNot applicable
Hi there,
Thanks for sharing this
Is there a modification to this code to add custom fields as well?- DanMcGFrequent Visitor
Hey Anonymous,
I think it should work with custom fields.
If you put in a JQL query that has custom fields included in its definition, that should work.
Just made a better one (doesn't pull all fields, so should be much better for bigger queries). For auth follow the same instructions as before.
NOTE: with this one, you can also specifiy how many issues is retured in each request (a larger number makes it run faster), but if you're returing a lot of columns Jira may limit this and so you will miss some info. So if you're returning a lot of info and want to make it >50, be careful and do some testing that you're getting all the data you expect (a way to test this is looking at items returned in the query versus what the JQL returns in Jira) - my advice would be to just leave it at 50 😊.
let Source = (optional jql as text, optional fields as text, optional itemsPerQuery as number) => let // itemsPerQuery = null,//50, // jql = null,//"project = ABC", // fields = "assignee,key,summary,cReated", jiraDomain = "https://<youdomain>.atlassian.net", jqlConverted = if jql = null then "" else jql, fieldsConverted = if fields = "id" then "key" else fields, itemsPerQueryConverted = if itemsPerQuery = null then 50 else Number.Round(itemsPerQuery,0), #"(convertFieldsNamesToIds)" = (fieldsToGet as text) => let // jiraDomain = "https://rimestechnologies.atlassian.net", // fields = "assignee,key,Client Id (global),summary", fieldsToGetAsList = Text.Split(Text.Lower(fieldsToGet),","), jiraFieldNameList = Json.Document(Web.Contents(jiraDomain & "/rest/api/3/field")), fieldRecordsToTable = Table.FromList(jiraFieldNameList, Splitter.SplitByNothing(), null, null, ExtraValues.Error), expandFieldRecords = Table.ExpandRecordColumn(fieldRecordsToTable, "Column1", {"id", "key", "name"}, {"id", "key", "name"}), addGetFieldCheck = Table.AddColumn(expandFieldRecords, "getField?", each List.Contains(fieldsToGetAsList,Text.Lower([name]))), filterToFieldsToGet = Table.SelectRows(addGetFieldCheck, each ([#"getField?"] = true)), createFieldsString = Text.Combine(Table.Column(filterToFieldsToGet,"id"),",") in createFieldsString, #"(createRenameListFromIds)" = (idsToGetNames as text) => let // jiraDomain = "https://rimestechnologies.atlassian.net", // idsToGetNames = "summary,customfield_12976,assignee,created", idsToGetNamesAsList = Text.Split(Text.Lower(idsToGetNames),","), jiraFieldNameList = Json.Document(Web.Contents(jiraDomain & "/rest/api/3/field")), fieldRecordsToTable = Table.FromList(jiraFieldNameList, Splitter.SplitByNothing(), null, null, ExtraValues.Error), expandFieldRecords = Table.ExpandRecordColumn(fieldRecordsToTable, "Column1", {"id", "key", "name"}, {"id", "key", "name"}), addFieldCheck = Table.AddColumn(expandFieldRecords, "getField?", each List.Contains(idsToGetNamesAsList,Text.Lower([id]))), filterToFields = Table.SelectRows(addFieldCheck, each ([#"getField?"] = true)), addRenameLists = Table.AddColumn(filterToFields, "renameLists", each {[id],[name]}), createListOfLists = Table.Column(addRenameLists,"renameLists") in createListOfLists, createQueryTable = Table.FromList( List.Generate( () => 0, each _ < Json.Document(Web.Contents(jiraDomain & "/rest/api/3/search", [RelativePath= "?fields=key" & "&jql=" & jqlConverted ]))[total], each _ + itemsPerQueryConverted ) , Splitter.SplitByNothing(), null, null, ExtraValues.Error ), addQueries = Table.AddColumn(createQueryTable, "queryLists", each Json.Document(Web.Contents( jiraDomain & "/rest/api/3/search" ,[RelativePath= "?startAt=" & Text.From([Column1]) & "&jql=" & jqlConverted & "&maxResults=" & Text.From(itemsPerQueryConverted) & "&fields=" & Text.From(if fieldsConverted = null then "*all" else #"(convertFieldsNamesToIds)"(fieldsConverted)) ] ))[issues]), removeStartAt = Table.RemoveColumns(addQueries,{"Column1"}), expandQueryLists = Table.ExpandListColumn(removeStartAt, "queryLists"), expandIssues = Table.ExpandRecordColumn(expandQueryLists, "queryLists", {"id", "key", "fields"}, {"id", "key", "fields"}), expandFields = if List.First(Table.Column(expandIssues,"fields")) = null then expandIssues else Table.ExpandRecordColumn(expandIssues, "fields", Record.FieldNames(List.First(Table.Column(expandIssues,"fields"))), Record.FieldNames(List.First(Table.Column(expandIssues,"fields")))), renameFields = if List.First(Table.Column(expandIssues,"fields")) = null then Table.RemoveColumns(expandFields,{"fields"}) else Table.RenameColumns(expandFields,#"(createRenameListFromIds)"(Text.Combine(Record.FieldNames(List.First(Table.Column(expandIssues,"fields"))),","))) in renameFields in Source
