Join the Fabric FabCon Global Hackathon—running virtually through Nov 3. Open to all skill levels. $10,000 in prizes! Register now.
lavdeepk
Resolver I
Resolver I
Apart from Excel and power bi. where we can use power query?
Hi All,
I am aware of only two applications Excel and Power Bi where I can use power query. Is there any other Microsoft tool where I can use power query?
Lavdeep
negi007
@lavdeepk
Yes, it is mostly used in Ms-Excel and MS-PowerBI. But now it's engine is used in other MS application as well.
Where can you use Power Query?
The following table lists Microsoft products and services where Power Query can be found.
WHERE CAN YOU USE POWER QUERY?
Product M engine1 Power Query
Desktop2
Power Query
Online3
Dataflows4
Excel for Windows Yes Yes No No
Excel for Mac Yes No No No
Power BI Yes Yes Yes Yes
Power Apps Yes No Yes Yes
Power Automate Yes No Yes No
Azure Data Factory Yes No Yes Yes
SQL Server Integration Services Yes No No No
SQL Server Analysis Services Yes Yes No No
Dynamics 365 Customer Insights Yes No Yes Yes
1M engine The underlying query execution engine that runs queries expressed in the Power Query formula language ("M").
2Power Query Desktop The Power Query experience found in desktop applications.
3Power Query Online The Power Query experience found in web browser applications.
4Dataflows Power Query as a service that runs in the cloud and is product-agnostic. The stored result can be used in other applications as services.
Links for further reading
https://docs.microsoft.com/en-us/power-query/power-query-what-is-power-query#where-can-you-use-power...
https://chandoo.org/wp/power-query-tutorial/#:~:text=Power%20Query%20is%20used%20to,system%20%E2%80%...
Appreciate your Kudos
Follow me on linkedin
negi007
@lavdeepk
Desktop2
Power Query
Online3
Dataflows4
The Power Automate SQL connector.
--Nate
