OscarSuarez10
Helper III
Helper III
Add index per proudct and year using power query
Hello How can I add an Index column using power query that starts in 0 like in the following table?
ProductYearIndex
A20190
A20201
A20212
A20223
B20190
B20201
B20212
B20223
C20190
C20201
C20212
C20223
2 ACCEPTED SOLUTIONS
Hi @OscarSuarez10 ,
You could try the query below.  You need to group rows by Product and then create the custom column.
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("TcuxCQAwCADBXawt1C5ldAxx/zUCgYQvr7hu2aIS5ktGH8IIJ+IieZIneZKneIqneOqfOQ==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [Product = _t, Year = _t]),
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"Product", type text}, {"Year", Int64.Type}}),
    #"Grouped Rows" = Table.Group(#"Changed Type", {"Product"}, {{"all", each _, type table [Product=text, Year=number]}}),
    #"Added Custom" = Table.AddColumn(#"Grouped Rows", "Custom", each Table.AddIndexColumn([all], "SubCount",0,1)),
    #"Removed Columns" = Table.RemoveColumns(#"Added Custom",{"all"}),
    #"Expanded Custom" = Table.ExpandTableColumn(#"Removed Columns", "Custom", {"Year", "SubCount"}, {"Custom.Year", "Custom.SubCount"})
    #"Expanded Custom"
Here is the output.
Cherry
Community Support Team _ Cherry Gao
Hi @OscarSuarez10 ,
some time ago I recorded a screencast that shows how to perform the steps via the UI: https://www.youtube.com/watch?v=-3KFZaYImEY
HotChilli
Add an Index (from 0) call it IndexFromZero
Add a custom column with:
Number.Mod([IndexFromZero],4))
Sorry but when is 2019 I need that it appears Inex = 0 because is the first year and the same for 2020 = 1, 2021 = 2 and so on,  and I got this:indice mal.JPG
Hi @OscarSuarez10 ,
    #"Expanded Custom"
Here is the output.
Cherry
Hi @OscarSuarez10 ,
The code I posted works for the data you provided.
It depends on the data being in a similar order to your sample.
Do you want to post the real data OR if you want, just write a simple IF statement
if Year = 2019 then 0 else if Year = 2018 then...........
make sure you change the data type of Year to number before adding the column
FabCon Global Hackathon
