niculcig
API Call POST Method - Power Query - Syntax Help
Hello and good day everyone,
I've been trying for 3 days to connect to an API using Post Method. I been using different methods that I found on some forums but still I can't get the correct result.
This is what I got:
-URLhttps://e-api.gemius.com/api/markets
-Authentication Token : Bearer XXXXX
-JSON response from postman:
[{"id":2,"iso":"be","name":"Belgium"}]
-Example request from the documentation:
curl -H 'Authorization: Bearer __TOKEN__' -H 'Content-Type: application/json' -X POST 'https://eapi.
gemius.com/api/markets'
I tried this with Power Query with no success :
AuthKey = "Bearer XXX",
url = "https://e-api.gemius.com/api/markets",
body = {id="2", iso="be", name="be"},
Source = Json.Document(Web.Contents(url,[
Headers = [#"Authorization"=AuthKey ,
#"Content-Type"="application/json"],
Content = Text.ToBinary(body)
Source
I don't have a lot of experience working with API's if someone can help me it would be wonderfull.
Thx!
ImkeF
Hi @niculcig ,
the Power BI /Power Query /M-syntax to create a record or a list is quite the opposite of how you do it in JSON.
So step
in your query is not valid.
To create this record in M, you have to use square brackets instead:
body = [id="2", iso="be", name="be"]
