Join us at FabCon Vienna from September 15-18, 2025, for the ultimate Fabric, Power BI, SQL, and AI community-led learning event. Save €200 with code FABCOMM. Get registered
VivienneVereen
Fabric Capacity Scaling and Power BI - What happens when Power BI model guardrails are exceeded?
Introduction
In Microsoft Fabric, capacities provide the compute power for a comprehensive suite of analytics tools. A single capacity supports all Fabric experiences, including Power BI. Microsoft Fabric offers a robust set of analytics experiences designed to work together seamlessly - it is integrated, secured, and governed. Additionally, there is flexibility with pay-as-you-go or reservation purchase options, and you can get started with a 60-day free trial (Getting Started | Microsoft Fabric).
Fabric Capacity Scaling and Features
There are many features that make capacities flexible for performance and cost management, such as bursting and smoothing:
  • Bursting: Allows Fabric to run operations at top speeds.
  • Smoothing: Adjusts the accounting of spikes to spread over longer periods by using unneeded capacity from other parts of the day. Interactive operations are smoothed over a minimum of 5 minutes or longer, while background operations are smoothed over 24 hours.
Even with these features providing scalability and optimizing performance, there may still be a need to scale a Fabric capacity to avoid throttling.
Planning Your Fabric Capacity
When planning your Fabric capacity strategy, it is important to understand how consumption is calculated.
There are out-of-the-box monitoring tools available such as the Fabric Capacity Metrics App, Surge Protection (Preview), and Workspace Monitoring (Preview).
One great feature of Fabric SKUs is the ability to seamlessly scale and pause/resume within the Azure Portal. However, it is important to note that there are specific SKU limits and guardrails for Power BI workloads that need to be considered when planning a capacity strategy.
Additional Resources
My colleague Pat Mahoney has an excellent YouTube playlist about all things Fabric Capacities, including topics on Capacity Metrics App, automating pause/resume, dynamic scaling, and multi-capacity strategies to protect your workloads. I highly recommend checking these out!
Power BI Testing and Findings
Import Model
Testing for import models was performed on F16 and F8 SKUs.
Model Information
Checked Total Size in Memory with Vertipaq Analyzer in DAX Studio and confirmed it to be 3.04 GB.
F16 SKU
F16 SKU Guardrails:
The Max Memory limit for F16 SKU is 5 GB.
The report works:
F8 Scale Down
F8 SKU Guardrails:
The Max Memory limit for F16 SKU is 3 GB.
Initially, the report still works:
However, after a few minutes the report fails to load with the “exceeds the maximum size limit on disk” error:
Attempting to refresh the model, the refresh fails with the same error:
F16 Scale Up
After scaling up to F16 – the report works again, no model refresh required:
Direct Lake Model
Testing for Direct Lake models was performed on F64 and F32 SKUs.
Model Information
It was confirmed via Lakehouse SQL Endpoint query that the largest table in the model has a row count of 301,337,872:
Fallback is disabled – model will not fall back to DirectQuery when guardrails are exceeded:
Automatic Reframing is disabled:
F64 SKU
F64 SKU Guardrails:
The Direct Lake rows per table limit is 1.5 billion.
The report works:
F32 Scale Down
F32 SKU Guardrails:
The Direct Lake rows per table limit is 300 million.
Report fails to load - if storage Direct Lake Behavior setting had been set to automatic, the report would have loaded but fallen back to DirectQuery:
F64 Scale Up
Note, some limitations regarding licensing:
After scaling up to F64 – the report works again, no reframing required:
Summary
For Fabric and Power BI Premium, each SKU has specific limits and other constraints specific to Power BI workloads. When scaling a Fabric capacity, it is important to keep these guardrails in mind and ensure they are not exceeded so that Power BI reports remain accessible to business users. More details can be found here.
The behavior of Import and Direct Lake semantic models and reports during capacity scaling was tested:
  • For Import models, if the max memory limitation is exceeded after scaling down, the report will fail to load, and the model cannot be refreshed. However, immediately after scaling up, the report will work again without requiring an additional model refresh.
  • For Direct Lake models, if the direct lake rows per table limitation is exceeded after scaling down (given fallback is disabled), the report will fail to load. If fallback is set to automatic, the report will load but fall back to DirectQuery mode. Upon scaling up, the report will work again without needing reframing.
References
Fabric Capacities YouTube playlist:
Capacities:
Surge Protection (Preview):
Workspace Monitoring (Preview):
Direct Lake:
Power BI SKU Guardrails:
DAX Studio:
