Karola
Advocate I
5 years agoStatus:
New
Power Bi embedded: round edges not visible anymore when using outline
I have multiple buttons etc in my report where I have round edges in the outline. Now everything is fine in Desktop and Service but in Embedded the round edges are gone. example: desktop: ...
shreyas4315
5 years agoRegular Visitor
Hi I am facing the same issue. The corners on buttons are no longer rounded when the report is embedded. Although, they do appear to have rounded corners when viewing inside the powerbi service. I have attached screenshots for both.
When Embededd:
Inside the Service (Check the Page numbers):
